Results 1 to 10 of 10
Thread: Leaky delta faucet
    DIY Junior Member WestCoaster25's Avatar
    Jul 2013
    British Columbia
    Default Leaky delta faucet
    I have a delta faucet which is leaking from the handle (from the hot water side). I replaced the "O" ring but now can't get the cartridge to sit and as a result the lock ring just spins around. I lined up the grooves with the cartridge but it still sits too high. Then, I tried to replace the cartridge without the ring and the leak is worse than ever. What to do?
    Jul 2013
    British Columbia
    Should I buy a new cartridge? I was hoping to just fix this, rather than have to buy another faucet.
    Aug 2009
    South*East
    Replace the stem. Delta faucets have a lifetime warranty. Call there 800# and they will send you the stem free of charge.
    John
    We do not "repair" Delta stems, we replace them with a new unit. Delta's number is 800-345-DELT. You need "quarter turn" replacement stems, but most of those in the "big box stores" are "half turn versions".
    Jul 2013
    British Columbia
    THANKS!! I'm sure glad I found this forum - phoned Delta and they will send replacement parts. Really appreciate all your advice.
    Jul 2013
    British Columbia
    I went to see if I could at least use the cold water faucet, but now the cold water comes out where the hot water handle used to be. I do have the cartridge screwed in. Why do you think this is happening? The cold water was working fine before I started this 'fix-it' project...
    Nov 2009
    Victor, MT
    I sounds like maybe the seat (rubber washer) and spring are missing, it could be they got out of place when you pulled the cartridge because that would explain why the cartridge wouldn't go back in correctly. They may have washed out while you were working on the valve.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Back pressure from resistance of water flow through the aerator causes it to back up into hot line and then the cold water comes out at the hot handle. If you remove the aerator it may flow out the spout and not leak into the hot line as much. Just cleaning it may help too. Water under pressure takes the path of least resistance.
    Jul 2013
    British Columbia
    Thanks for that. I fiddled with the seat and spring and that seemed to do the trick - I now have cold water coming out of the cold tap...things are getting better...
    Jul 2013
    British Columbia
    The aerator does seem gummy - not sure how to remove it though without taking the whole thing apart. Will have to look that up.
  1. Leaky Delta Jetted Shower
    By Kiko in forum Shower & bathtub Forum & Blog
    Last Post: 12-07-2009, 07:51 AM
  2. How do I fix a leaky faucet?
    By cubfan4evr in forum Shower & bathtub Forum & Blog
    Last Post: 09-03-2008, 04:11 PM
  3. Leaky Tub Faucet
    By Daniee in forum Shower & bathtub Forum & Blog
    Last Post: 04-29-2007, 02:17 PM
  4. Leaky tub faucet
    By ktanderson8 in forum Shower & bathtub Forum & Blog
    Last Post: 01-15-2007, 11:47 AM
  5. Leaky faucet
    By rancar in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2006, 04:44 AM
