Results 1 to 6 of 6
Thread: Quick question about shower drain...
    DIY Junior Member BRADO's Avatar
    Jul 2013
    Ontario Canada
    Default Quick question about shower drain...
    Hi all, I'm in Ontario Can. not sure what code calls for (think 2") but have found my basement shower drain is plumbed with 1-1/2" ABS for the drain...I'm starting to finish the bathroom now and am at the shower install. OK if I use a 2.5 GPM showerhead?? I know it will drain slower but hope not to stand in water while showering.
    Brad
    From comments here, I think 1.5" on a shower is still code in Canada. With one showerhead and proper slope, it should be okay.
    Jul 2013
    Ontario Canada
    Thats what I thought but doesn't hurt to ask thanks, for your help Jim.
    Brad
    Jul 2009
    North Vancouver, BC
    2.5 GPM is nothing. Do you know the water level drop from the top of the basement floor to the level of water in the P-Trap? If you have 5"-8" you could easily run 12-14 GPM down that line. I would not be worried about having a couple fixtures on your 1.5" line at all. JW
    Jul 2013
    Ontario Canada
    Hey John, the difference is about 4", tricky to be exact as to see where the level is in the riser but no more than 4" up to the floor, with the 2 layers of motar, membrane and tile prob. be 6" to top of drain (shluter).
    Brad
    Jul 2009
    North Vancouver, BC
    The Schluter drain has a nice angled sides (inside) and has a high flow rate for standard drains. 4"-6" is average and all good.
  1. Replies: 2
    Last Post: 02-09-2013, 01:52 PM
  2. Quick Question about No-Hub
    By glnow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-09-2011, 04:39 AM
  3. Quick question on glass framed pivoting shower door hardware question
    By watson524 in forum Shower & bathtub Forum & Blog
    Last Post: 02-09-2011, 05:38 PM
  4. Quick (hopefully) WC to Tub drain question.
    By Kenolds in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-18-2010, 08:17 AM
  5. Quick Question
    By akantler in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2010, 08:35 PM
