Results 1 to 3 of 3
Thread: Junction box in attic mounted on truss support
    DIY Junior Member pex006's Avatar
    Jul 2012
    Pittsburgh, Pennsylvania
    Default Junction box in attic mounted on truss support
    Is it ok to mount a junction box to a roof truss support. They are 2x4 in size. The access to the attic is through a hole in my hallway that I have to get a ladder to go up through it. The junction box will be 10 feet from the access hole.
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by pex006 View Post
    You are doing fine. Secure the box well. Secure the cable or conduit properly. When in doubt, use a few more staples. Ten feet from the hatch is way more than enough. Don't fail to put a cover plate on the box when you are done. Or a light is fine as well. Just keep the cable or conduit well away from the hatch. I seem to remember it is 3'.
    Your picture shows a floor. Keep the cables or conduit behind those jacks and away from the center.
    Current code wants you to install a nailer if your cable is perpendicular to the ceiling joists. 1x3s will do the trick. That is good practice, the cable is nearly immune to damage then. Unless you go after it with an axe. Don't go after it with an axe.
    Jul 2012
    Thanks. I'll make sure it is well away from the floor.
  1. Floor mounted or wall mounted toilet?
    By Guest in forum Toilet Forum discussions
    Last Post: 03-02-2014, 10:52 PM
  2. junction box and code
    By lnfd27 in forum Electrical Forum discussion & Blog
    Last Post: 07-20-2008, 02:25 PM
  3. Exterior junction box?
    By Nate R in forum Electrical Forum discussion & Blog
    Last Post: 10-02-2007, 11:34 AM
  4. Floor truss question
    By r_2016 in forum Remodel Forum & Blog
    Last Post: 09-27-2007, 07:40 PM
  5. Drilling kitchen sink vent up through open web truss
    By Masonry321 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-14-2007, 05:01 AM
