Results 1 to 8 of 8
Thread: HELP! Replacing this P trap
    DIY Junior Member malbrax's Avatar
    Jul 2013
    toronto
    Default HELP! Replacing this P trap
    Is it possible to replace this setup with ABS?
    That is how it was originally set up, I tried removing the U trap to clean but it was rusted and broke from the 90 bend pipe. The U trap and the 90 bend both broke off and unfortunately the 90 bend pipe is either soldered or glued to the main drain pipe. How can I replace this without spending $$$$$$$ on a plumber as its something we can't afford at the moment. I am not really familiar with plumbing but I am trying my best!
    You need a brass trap, you cannot use a plastic one. You have to "melt" the solder from the old connection and pull it out, then remove the chrome plating at the same location on the new trap, then solder the new trap to the drain line.
    Jul 2013
    toronto
    would soldering a 1.25'' brass trap adapter let me have a plastic setup?
    If that is 1 1/4" copper, and you could find one, (I haven't seen any for the past 40 years).
    Plumber Sean Beck's Avatar
    Jun 2013
    Toronto, Ontario, Canada
    Cut the copper drain close to where it enters the wall, leaving a couple of inches. Use an 1.25" copper to 1.5" ABS MJ coupling and redo the drain in ABS. This is dependant on the property not being a high rise. If that's the case, then the drain would have to be done in either copper/brass or System 15 PVC.
    Nov 2010
    Maine
    Seems like a whole lot of fuss when you could just replace the trap with another chrome one.
    quote; Seems like a whole lot of fuss when you could just replace the trap with another chrome one.
    Yes, but some people like the challenge of converting a mole hill into a mountain.
    Jun 2013
    I think he said both sides of the trap had corroded and broken.
  1. Options in replacing a drum trap under tub
    By dave123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-05-2011, 11:50 AM
  2. Replacing Cast Iron Shower Drain / P-Trap & Replacing with ABS
    By n0teye in forum Shower & bathtub Forum & Blog
    Last Post: 08-29-2011, 02:36 PM
  3. Replacing old p trap - new vanity
    By wolfpacknc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2011, 11:52 AM
  4. replacing my bathtubs. Tub drain is threaded into the trap???
    By Dunebuggyjay in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-05-2010, 02:28 PM
  5. Removing/replacing lead trap
    By jdkimes in forum Shower & bathtub Forum & Blog
    Last Post: 01-14-2006, 06:47 AM
