Results 1 to 8 of 8
Thread: Metal Sheets on Studs
    DIY Member MAD King's Avatar
    Mar 2013
    Nashville, TN
    Default Metal Sheets on Studs
    Hello,
    I am remodelling my bathromm and found some metalsheets sticking on the studs.
    I am wondering what is this for since it doesn't hold anything together. They are just placed on the studs.
    Thank you
    Nov 2009
    VA
    Those are protector plates. They are required when plumbing/electrical is within ~1 1/4" from the face of the stud. It is to keep the drywall guys from sticking a screw through your piping/wiring.
    Mar 2013
    Nashville, TN
    Great. That explains it. Thank you very much.
    They work great, unless the carpenter get frustrated when his screws or nails keep hitting it, then he starts angling the screws trying to go over or under it, and when he is successful, THEN he puts a hole, or holes, in the water line.
    I have seen this.
    Scary when they get determined to do something...
    I did a job for a contractor friend. After it was finished, about 3 hours later, water started coming out under the door. When I found the nail his guys had managed to put through the copper line, I also found about 20 holes where they had tried to go through the plate until they were able to angle down under it.
    In the trades Dana's Avatar
    Jan 2009
    The more foolproof you make something, the more creative the fools become, eh? :-)
    Or we just get a better quality of fools.
  1. Pulling low voltage wires through metal studs
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 08-31-2009, 03:54 PM
  2. metal studs
    By Ian Gills in forum Remodel Forum & Blog
    Last Post: 04-05-2009, 11:24 AM
  3. Metal studs
    Last Post: 01-06-2009, 07:33 AM
  4. Anchoring Into Metal Studs
    By Verdeboy in forum Remodel Forum & Blog
    Last Post: 11-22-2007, 06:13 PM
  5. pvc thru metal studs
    By sulconst2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2005, 05:45 PM
