Thread: Goulds GT-15 Irri-gator
    DIY Junior Member Jmcc64's Avatar
    Nov 2009
    alabama
    Default Goulds GT-15 Irri-gator
    Gt-15 stopped working suddenly this spring. Took the back cap off, took the start capacitor off and it basically fell apart. Replaced capacitor but still nothing. No sounds. no humming, nothing. Power is getting to the pump. I can easily turn the shaft freely with my fingers. So I took it to a pump repair place and they say it needs to be replaced. Says the impeller melted ,most likely from running dry. (I guess it could've happened. It's been in service for almost 4 yrs and never had a problem before.) That said, if the impeller was melted to the diffuser (his words) would I be able to turn the shaft? I assume they checked the electrical on the pump before concluding that it was the impeller. Replacing those (2) items would cost around $60 as opposed to a new pump.
    Feb 2011
    NW Ontario, Canada
    If it got hot enough for a total meltdown, then maybe it's possible that the shaft decoupled from the impeller allowing it to spin free. Why don't you ask the repair shop for an explanation as to why the shaft spins free?
    If you got no sounds or vibration from the pump after you worked on it, then there is a good possibility that the motor overheated and died as well. Don't assume they checked the motor, ask them.
    Moderator valveman's Avatar
    Mar 2006
    My guess is that the pump deadheaded and melted down. That GT15 can only build 49 PSI if it is pumping from a storage tank. If it is lifting from a well, it won’t be able to even build 49 PSI. If you have a pressure switch, a setting of 30/50 is too high. If you are using a pump start relay, the sprinklers probably didn’t pop up when the pump came on, which melted the pump.
  1. Gator bite and tub shower problems
    By weasels2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-22-2013, 07:09 AM
  2. goulds pump
    By marquezrf in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-13-2011, 05:52 AM
  3. Thinking of replacing a Goulds Irri-Gator
    By PEW in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-20-2010, 01:23 PM
  4. How tightly should [Gator|Shark]bite fittings be screwed to threaded brass?
    By miamicanes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2009, 10:43 PM
  5. impeller on goulds j7s
    By spark in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-08-2009, 10:22 AM
