Results 1 to 2 of 2
Thread: 2x4 size difference
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Default 2x4 size difference
    I am framing my basement. I bought some 2x4s and I also kept some 2x4s from the old finished basement. I just found the actual width of the them are different. There are about 3 different measurements. The differences are about 1/8 to 1/16. Should I avoid mixing them?
    Sort of normal.
    Have you looked at camber yet?
    Most studs have a bend to them. Make sure that the camber is on the same side as you line them up, or the wall board will wave back and forth.
  1. Difference in resin?
    By Retiredguns in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-27-2012, 07:12 AM
  2. how much difference does 1/2 hp make in pumps?
    By rbig in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-11-2011, 10:13 AM
  3. What's the difference between the Neorest 500 and 600?
    By Meno in forum Toilet Forum discussions
    Last Post: 08-07-2008, 09:53 AM
  4. What's the difference between these valves?
    By jimithing78 in forum Shower & bathtub Forum & Blog
    Last Post: 12-20-2007, 07:12 PM
  5. Can't see the difference between these two
    By toolaholic in forum Toilet Forum discussions
    Last Post: 08-29-2007, 08:41 PM
