Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: 1/4 HardieBacker Board for Walls?
    DIY Member MAD King's Avatar
    Mar 2013
    Nashville, TN
    Default 1/4 HardieBacker Board for Walls?
    Hello,
    I have a lot of the 1/4 HardieBacker Cement Board left from floor tiling.
    When I put two together, can I use that for walls too?
    Thank you
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by MAD King View Post
    Hello,
    Thank you
    Never seen that done before. Maybe if the second sheet was thin-setted to the first it might fly. Might even be stronger....
    I think 1/4" is approved by the maker for wall tile but I would not trust it. If the two are bonded to each other I would bet you get a strong backer.
    JW
    Mar 2013
    Nashville, TN
    So you think if I would put a thinset between it would work and even be stronger? Theoretical it makes sense.
    Jul 2009
    North Vancouver, BC
    You need all four sides of cement board secured with studs or blocking. With this in place I would bet that if you nailed off the first layer with some smaller nails and then installed the second layer with a slurry coat of something like Laticrete 254 your net result would be stronger than a 1/2" layer of Hardie. Why not buy one sheet of 1/2" and do a small test.
    Set up a deflection test. Might save you some money if you can find out it works.
    The board should not flex inward more than 1/4" between 16" on center walls studs.
    L/360 deflection for a 16" center wall stud is very low under 1/16". This is very hard to meet with any backer board.
    I would mock up a test and then add 100 lbs of weight on your mock up. Measure the sag. Then check the sag on a 1/2" board. If you are within these ranges I would think your fine.
    What type of waterproofing are you planning to use over this install. If your skipping any waterproofing then having fuller sheets and less seams would be the way to go...
    JW
    Mar 2013
    Nashville, TN
    I contacted Hardie Backer and that is what they wrote me back:
    We do not recommend doubling them up but you can still use them on the wall. They are approved for wall l applications.
    THe do not recommend doubling them, but that doesn't mean that it can't be done to give a more sturdy application, right?
    Jul 2009
    North Vancouver, BC
    Perhaps there is a expansion issue or directional expansion.....?
    Could you adding some extra blocking to bring your span's between joists down to 12" center's, then 1/4" plywood then 1/4" hardie? JW
    Mar 2013
    Nashville, TN
    Quote Originally Posted by johnfrwhipple View Post
    Yes I could add a layer of plywood under, but that doesn't save me money. I have to buy the plywood first and I was trying to use the 1/4" hardie to save money.
    Jul 2009
    North Vancouver, BC
    Then increase the blocking between studs and make sure you install the sheets the same way (directional). Scrap 2"x4" lumber is everywhere and will cost you nothing to pick up.
    You never answered my question about waterproofing.
    You need to finalize the complete system before jumping in....
    Mar 2013
    Nashville, TN
    Will do this with the studs and I don't know what type of waterproofing I will use yet.
    Thank you
    Jul 2009
    North Vancouver, BC
    Thank you
    Are you building a tub and shower or just shower?
    Mar 2013
    Nashville, TN
    Both, but the tub area will be a lot later due the tight money. So this area will be empty until then.
    Jul 2009
    North Vancouver, BC
    So the project at this point is just the shower. What kind of shower drain are you using? Is the shower base ready made or are you making a custom one?
    Adding waterproofing to the job you can easily expect to pay another $60-90+ to waterproof the walls from the pan to about 6'. Typically 3'x3' shower needs one gallon on liquid membrane or one unit of Ardex 8+9 to waterproof it.
    I would not skip this step. JW
    Mar 2013
    Nashville, TN
    I don't think you need a waterproof wall. There will be not water standing on the wall for a longer time (gravity).
    I will add as a barrier 15 roof felt behind the backerboard. For the pan I got the membrane. Shower drain is a Luxe which I bought when I still had a job. lol.
    I am making an own pan.
    Jul 2009
    North Vancouver, BC
    I don't think you need a waterproof wall. ....
    I'd debate you on that point and caution you that with loads of off cuts and no topical waterproofing you might have a mess on your hands.
    JW
    Mar 2013
    Nashville, TN
    Physically a 15 roof felt between the studs and the cement board should be fine. If water runs behind grout and board it will be stopped by the felt and the liner of course.
    A membrane over the cement board is of course the better way or top of the line, but a felt behind will work also. Adding a membrane to the felt and leaving the cement board between like sandwich style, creates moisture.
    Correct me if I am wrong.
  1. FIBEROCK Tile Backerboard vs HardieBacker Cement Board
    By piezomot in forum Shower & bathtub Forum & Blog
    Last Post: 03-20-2013, 04:11 PM
  2. Waterproofing Walls for Neo Angle Shower Using Wedi Board
    By DanMcD in forum Shower & bathtub Forum & Blog
    Last Post: 10-21-2012, 06:06 AM
  3. Hardiebacker vs Greenboard
    By idoc4u in forum Shower & bathtub Forum & Blog
    Last Post: 03-16-2010, 05:30 PM
  4. Leveling a low spot AFTER laying HardieBacker Board
    By fishkiller in forum Remodel Forum & Blog
    Last Post: 01-31-2008, 05:35 AM
  5. How much green board or cement board for shower
    By jeffxjet in forum Remodel Forum & Blog
    Last Post: 10-26-2004, 11:00 AM
