5800 SXT start up
ra
Manitoba
Hi Pro`s
I just installed a water softener, i do not know how set this up at first time when i started it it spits lots of water thru drain pipe.
Not sure weather it is normal so i stopped it.
Can anybody suggest me from the start up procedure for new water softener please.
Thanks,
ditttohead
Water systems designer, R&D
Ontario California
Sorry, out of the office all day. I will try to post it for you in the morning.
Congrats on the new system!
And, what color is the injector, and the BLFC size? The BLFC should be indicated by the sticker on the injector assembly. Also confirm the DLFC button size, and what is your water temperature?
ditttohead
Ontario California
Here is a quick master programming guide.
1: set time to 12:01 P.M.
2: push “regen” button
3: push and hold ^ v buttons to enter master program mode
Push “regen” button between each step to get to next step
4: DF Gal, factory set, leave as-is
5: VT 5800
6: RT dF1b, set to dF2b
7: CT Fd, factory set, leave as-is
8: C set to 48
9: H 20, set to the actual water hardness
10: RS Set to SF
11: SF Set to 15
12: DO 14 factory set, leave as-is
13: RT 2:00 factory set, leave as-is
14: BW Set to 5
15: BD 60 factory set, leave as-is
16: B2 set to 5
16: RR Set to 5
17: BF set to 43 for .125 BLFC, 22 for .25 BLFC
18: FM t0.7 factory set, leave as-is
