Results 1 to 3 of 3
Thread: Backwater valve installation question
    DIY Junior Member darren_t_johnson's Avatar
    Apr 2013
    Ottawa, Ontario, Canada
    Default Backwater valve installation question
    Hi,
    I'm going to be installing a Mainline backwater valve, and the instructions say I need at least 2% grade.
    I over analyze things... so does that mean the inlet pipe and outlet pipe have to have at least 2% grade, and the backwate valve should be level? The outlet pipe is already 3/4" lower then the inlet pipe.
    Or should the backwater valve itself be installed on a slope? This doesn't sound right to because it the unit is slopped too much, the flap might not close properly.
    Has anyone installed one before and/or offer advice?
    Darren
    2% is the STANDARD minimum slope for a properly installed drain line. Your problem, if anything is that the inlet and outlet are 3/4' lower which creates a problem in a "straight pipe". Unless you can excavate enough pipe to make up that 3/4", you will have to install the BWV with a "backwards tilt" to make it fit.
    Apr 2013
    Hi hj,
    yes, 2% is the "1/4inch per foot" minimum that is required. I'm digging up a lot, and have more then enough room to make up that 3/4" difference.
    My main concern was that should the Mainline backwater valve unit itself be level, and the inlet and outlet pipes should have the 2% minimum grade.
    Or is the backwater value supposed be tilted so that the 2% grade is consistent across the valve unit. The instructions for the valve are vague about this, and I haven't gotten any feedback from the Mainline website.
    NEVERMIND.
    I was just typing my response and realized that the 3/4" difference is more than the required 2% grade... for some reason I thought it was not.... so the 2% grade minimum is referring to the inlet and outlet pipe.
    sometimes it helps to talk/type it out...
    Thanks, and sorry for posting a pointless question.
  1. Backwater Valve
    By dlarrivee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2011, 11:52 AM
  2. backwater valve
    By maddon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2011, 09:20 AM
  3. Backwater Valve
    By chas22 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2009, 06:32 PM
  4. Backwater valve installation. Please advise
    By Pan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-28-2008, 09:14 PM
  5. Mainline Fullport Backwater Valve Question
    By mccallum in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-21-2008, 05:17 AM
