Results 16 to 30 of 37
Thread: ANSI Shear Testing Procedures:
  1. #16
    Jul 2009
    North Vancouver, BC
    Default Shear Testing EOTA (ETAG-022) Convert newton/millimeter˛ [N/mm˛] <—> psi [psi]
    Posts deleted by John Whipple
  2. #17
    Jul 2009
    North Vancouver, BC
    Default Kerdi / Ditra Tensile & Shear Testing Data (Ditra 0.2 N/mm2 )
  3. #18
    Pull strength is only important related to the tile weight since you aren't going to be able to grab the tile and pull.
  4. #19
    Jul 2009
    North Vancouver, BC
  5. #20
    Jul 2009
    North Vancouver, BC
    Default Shear Testing Laticrete 317 (7 day set) 254 (6 day spot set)
  6. #21
    Jul 2009
    North Vancouver, BC
    Default EN 12004 - European Standard for Tile Adhesives
  7. #22
    Jul 2009
    North Vancouver, BC
    Default Deformability Test for lateral shear ratings for Mortars
  8. #23
    Jul 2009
    North Vancouver, BC
    Default Master Tilers Association - Australian Testing Procedures
  9. #24
    Jul 2009
    North Vancouver, BC
    Default Kerdi set over drywall with Laticrete 254 - Shear Test Results 62.39 PSI
  10. #25
    Jul 2009
    North Vancouver, BC
    Default Noble Company WallSeal - Shear Testing with Laticrete 254 93.75 psi over drywall
  11. #26
    Jul 2009
    North Vancouver, BC
    Default ISOMAT S.A. vs ARDEX - Cementious Waterproofing Showdown
  12. #27
    Jul 2009
    North Vancouver, BC
    Default Shear Testing Noble Company Noble Deck vs GreenSkin
  13. #28
    Jul 2009
    North Vancouver, BC
    Default Strata Mat by Laticrete - Shear Testing Data in PSI (>93.91)
  14. #29
    Jul 2009
    North Vancouver, BC
    Default Dita Shear Rating (Head to Head vs StrataMat by Laticrete) 88.64 PSI
  15. #30
    FWIW, thinset does not stick to the top side of Ditra - it gets locked in place by the reverse tapered holes (it does get embedded in the fleece on the bottom, though)...plus, not sure why you are mixing your thinset at +20%, if I understand your descriptions. Since Ditra is designed only as a floor membrane, shear is pretty much irrelevant.
    The important part of this is that the system must support the tile on the wall or floor. For practical purposes, how much is enough? On an average sized tile, say a 6x6, the spec calls for a minimum of 50psi, so that's 36X50 or 1800#. The only time this becomes a practical matter is if the tile is not installed properly without the requisite expansion provisions...then, it's not the membrane or tile's fault, it's the installers. There's no tile out there that would stress the system to actually hold it from gravity. You are NOT going to pull the tile out unless trying to, and then, it may be tedious. For say a remodel, higher strengths may be a disadvantage when trying to remove it.
    I think from a practical understanding, though, it's illustrative that a dryset mortar is perfectly fine to hold pretty much any tile up when using a membrane, as the membrane itself will likely fail before the thinset. And, when using a waterproof membrane and an unmodified thinset properly mixed, it should achieve its maximum strength because it holds the moisture in to aid the cement for the strongest cure possible. Excess moisture may ultimately weaken it, though.
    It's interesting, though...
  1. Direct Vent Stove Install/Ansi Rating
    By The old college try in forum HVAC Heating & Cooling
    Last Post: 12-17-2011, 05:52 PM
  2. Procedures for "T" Key to dislodge from well pitless adapter - help!
    By SergioMastro in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-30-2008, 11:32 AM
  3. Air Testing
    By nelsonba in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2007, 09:12 PM
  4. PVB testing
    By ToolsRMe in forum Irrigation / Sprinkler Forum
    Last Post: 06-06-2007, 01:16 PM
  5. Well Testing
    By Budster in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-09-2006, 11:15 AM
