Results 1 to 2 of 2
Thread: Sealing around septic pipe
    DIY Member Geo422's Avatar
    Feb 2012
    Cin oh
    Default Sealing around septic pipe
    Hi my septic pipe runs through my concrete basement wall and sealed with Hydraulic Cement . Now the ground water is seeping in with a heavy rain it a good leak. Is there a better way to seal this up around the pipe? Wanted to asked before I started digging.I have a septic system. Thanks george
    I think hydraulic cement is the best material for the job. Since it is leaking, I would have to suspect a poor job was done in applying the cement and therefore it should be redone.
  1. Connect septic pipe to septic tank????
    By Blueboat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-28-2012, 10:10 AM
  2. sealing gas pipe threads ?
    By Fabricator in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-03-2010, 05:29 PM
  3. Sealing supply pipe
    By vaman in forum Irrigation / Sprinkler Forum
    Last Post: 10-20-2009, 07:28 AM
  4. thread sealing... pipe or dope?
    By Hube in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-08-2007, 12:45 PM
  5. sealing tub outlet pipe?
    By Kman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-19-2006, 07:02 AM
