Thread: kenmore softner water from drain keeps flowing
    Default kenmore softner water from drain keeps flowing
    The Kenmore water softener model 625383760 the water flows from drain and will not stop unless I force the regeneration cycle to close the valve. Once this is done the machine works for a few days and then the same drain problem occurs. As the rotor turns and the wire connections are okay the technician at Sears seems to think the electronic panel is the problem. Since this part cost about $200 I was thinking it is not really worth it. Since the unit is only 3 years old I was writing to ask if anyone else had any opinions on what the problem could be with this unit.
    Jan 2012
    California
    Landfill material. Sorry to say, but only Sears will touch the unit, most softener technicians wont.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by rfhjr View Post
    I believe the stem on the rotor is twisted cause by the rotor seal. Replacing both will solve the problem of the time being then the same thing will happen with the new parts. I agree with Dittohead, landfill material.
    Thank you for the feedback. What is unusual with this unit is after I force the regeneration cycle it may work for 3 days and then the same problem occurs where it gets stuck in the drain mode. Sometimes I get an Err 4 code but usually if I unplug the unit to reset it goes away.
  1. Water softner flowing backwards.
    By chachie in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-07-2012, 06:41 AM
  2. Is this a drain? (above water softner loop)
    By RobHydell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-23-2012, 07:13 AM
  3. Kenmore water softner not drawing brine
    By SHP in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-13-2011, 09:36 AM
  4. Kenmore water softner: Water going in drain pipe continuously
    By gagan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-21-2010, 12:34 PM
  5. Culligan mark 100 water softner water flowing to brine line all the time
    By seahawk99ca in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2007, 09:35 AM
