Thread: Newbie Installing Water Filter -- Small Leaks Driving Me Crazy!
    DIY Junior Member Richard Lowe's Avatar
    Jul 2013
    California
    Default Newbie Installing Water Filter -- Small Leaks Driving Me Crazy!
    Hi all!
    New to the forum because I'm trying to tackle my first plumbing job on our house. I'm installing a Culligan water filter but can't seem to stop the connector joint from leaking.
    I'm such a newbie that I don't even know the terminology, so bear with me:
    I have a 1/2" tube going from my water supply to a brass T-joint that has a 1/2" opening and a 3/8" opening. From the 1/2" opening, a tube runs to my faucet. From the 3/8" opening, I have a 3/8" to 1/4" adapter-thing, where the tube connects and runs to the water filter.
    When I turn my water back on, a very small leak comes from the 3/8" to 1/4" adapter and I can't seem to get it to stop. I used teflon tape and made sure the nut is on tight, but still can't figure it out. (See photo, the red lines indicate the leak.)
    Any ideas? I'd love to figure it out myself without having to call a plumber, because I feel like I'm so close to being done!
    Thank you in advance!
    If you have a compression fitting there with a sleeve, then it won't work with Tape.
    Compression fittings, no tape
    Lav supplies with rubber cones on the large end or flat seals on the small end for sealing, no tape
    Flat rubber washer, no tape
    Tape does NOT help seal a compression connection, but it should not cause leaks either. I am not sure what kind of 3/8X1/4 adapter that is and whether you have a 'support sleeve" inside the 1/4 connection.
    Feb 2011
    NW Ontario, Canada
    ... and whether you have a 'support sleeve" inside the 1/4 connection.
    Ja, look for parts left over that look like this:
  1. Driving me crazy, either HOT or COOOOLD!
    By JLinder in forum Shower & bathtub Forum & Blog
    Last Post: 06-27-2009, 02:54 PM
  2. I need sleep! Noisy air pump is driving me crazy
    By tlvancouver in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-23-2008, 08:45 AM
  3. This faucet drain leak is driving me crazy, pls help!!
    By xtahoex in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-15-2008, 04:21 AM
  4. Kohler San Raphael flapper driving me CRAZY
    By PabNYC in forum Toilet Forum discussions
    Last Post: 01-27-2008, 11:02 AM
  5. Shower plumbing driving me crazy!
    By deanbrew in forum Shower & bathtub Forum & Blog
    Last Post: 10-19-2004, 07:13 PM
