Results 1 to 4 of 4
Thread: Shower Drain Leaking from Unsupported Shower Base
Hybrid View
    DIY Junior Member msche398's Avatar
    Jul 2013
    Greenville, South Carolina
    Default Shower Drain Leaking from Unsupported Shower Base
    I have a single-piece fiberglass shower that is leaking from the drain. The cause is that the base is not supported well and the bottom flexes, causing the drain to loosen. It has been tightened several times but seems to keep coming loose.
    Any suggestions on how to adequately support the shower so that the bottom doesn't flex? It is located on a 2nd floor.
    Jul 2009
    North Vancouver, BC
    There are many ways to support this section of your shower. You would need access from below. Can you gain access and then post a couple of pictures?
    With a few simple Strong Tie Brackets and some common 2"x4" stock you would be able to support the area around the drain.
    We love working with spray foam products and you might weight the drain area with a garbage can of water 15 Gallons or so should give you a 120 pound brace and then spray foam the area. This would work only for smaller gaps so before jumping in get the hole opened up and send us some pictures.
    Do you know how to post pictures here on Terry's page?
    JW
    Some of those were installed with putty.
    You may need to remove the old drain and reinstall a new one with Silicone.
    At that time you can add something below the pan to try to prevent the movement.
    Jul 2013
    Ok. I will first work on opening up the ceiling below and getting some pictures.
  1. condensation/leaking around base of Vikrell shower pan in basement
    By greyconman in forum Shower & bathtub Forum & Blog
    Last Post: 11-18-2009, 08:36 PM
  2. Leaking terrazzo shower base drain seal
    By bob_4554 in forum Shower & bathtub Forum & Blog
    Last Post: 09-04-2008, 11:02 AM
  3. shower drain sits above the base
    By keithdeanne in forum Shower & bathtub Forum & Blog
    Last Post: 02-02-2008, 02:40 PM
  4. Need help replacing shower drain base
    By GlobalTerrain in forum Shower & bathtub Forum & Blog
    Last Post: 09-15-2007, 07:57 PM
  5. shower w/ concrete base leaking
    By debbiec in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2007, 06:12 PM
