Results 1 to 12 of 12
Thread: 3/4" or 1/2" thermostatic valve
    DIY Member stephenson's Avatar
    Oct 2011
    Northern Virginia
    Default 3/4" or 1/2" thermostatic valve
    In a previous post I asked about using a transfer valve for three fixtures in shower ...wife finally decided she only wanted two (shower and a separate hand held) so we shifted from using a transfer valve to using separate volume valves, but local plumbing supply house is telling her she doesn't need 3/4" thermo valve and should use 1/2" - given this is second floor master bath on a well with pressure tank, I think we do, and worst case while more expensive by about $100 it doesn't seem like it could hurt. Thermo valve is Kohler 2975 and volume valves are K 2977.
    I was gonna just T off the output side of the thermo valve and run to each fixture head. Should i just go straight up to a T and run left and right off that, or is it OK to run T "sideways" off line to shower then other fixture off that? i am assuming when one is open and you select the other volume valve there will be some momentary rebalancing since is a simple T design? Could I just use the tub outlet on the thermo valve instead?
    Some companies say NOT to use the tub outlet for a shower fixture, but do not explain why. As for the valve size, it depends on how much water you need. A recent test found that if you have a high volume valve and low volume heads the temperature may not stay constant.
    Jul 2009
    North Vancouver, BC
    ... A recent test found that if you have a high volume valve and low volume heads the temperature may not stay constant.
    Interesting HJ - where did you read this study?
    Oct 2011
    Northern Virginia
    I was planning on "matching" with 3/4 tstat to 3/4 volume control,or 1/2 to 1/2 if that was the recommendation.
    A further point is that I am using CVPC which has smaller internal diameter than copper or PEX, so 3/4" may not provide that much difference.
    It was in one of last month's trade magazines, but I cannot remember which one, since I get so many, and was in relation to the current practice of installing a large valve with a "lot" of devices, but only using one or two at a time.
    Jul 2009
    North Vancouver, BC
    Your 3/4" pipe is not going to be the same as 3/4" copper. Closer to 1/2".
    I would swap out and go with two flow valves verses the "Pick 1of 3 Style".
    It's best when Mommy and Daddy can share the shower and stay warm together. My wife always gets the shower fixture when we take a shower together - I'm not complaining any shower time with Mommy is worth any personal sacrifice I have to make!
    Oct 2011
    Northern Virginia
    So, checked with Kohler and they confirmed to just match diameters ... wife ordered the 3/4" versions of the thermostatic valve and two volume valves. Think I'll test it before closing walls in :-)
    Jul 2009
    North Vancouver, BC
    Isolated the new plumbing work and bring the pressure up to 200PSI and see if your work can hold that for a hour. JW
    Oct 2011
    Northern Virginia
    Got the 3/4" valves - nice work by Kohler, and looks to be pretty straightforward to install and plumb. A bit confused now, though.
    I will run 3/4" pipe from tvalve to the volume valves via a simple T ... thermo valve near waist high, then 3/4" up towards the shower arm drop ear with a T between the two that runs to the second valve about a foot away with 3/4 leading to the drop ear for a hand held shower. My confusion ... aren't most shower arms 1/2" ... and, aren't most of the hand held shower supply elbows 1/2"? I have always used 1/2 valves and plumbing ... am I missing something REALLY simple?
    INdividual shower outlets are regulated to a maximum of 2.5gpm, so there's not much need to make them for bigger than 1/2". But, reducing fittings are readily available. It becomes a max flow issue when you start to want to run more than one at a time - this is where your 3/4" supply can keep them all flowing at their max.
    Oct 2011
    Northern Virginia
    Thanks ...so just use 3/4 in long runs and reduce to 1/2 prior to the drop ear?
    That should work...
  1. Thermostatic shower system 1/2" enough or need 3/4"??
    By mcu in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2011, 08:42 PM
  2. 1/2 " Kohler K-679 thermostatic valve good enough flow ?
    By Tamtony in forum Shower & bathtub Forum & Blog
    Last Post: 03-26-2011, 07:42 PM
  3. What does a thermostatic valve do while "waiting" for hot water?
    By Palladio in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2008, 09:49 PM
  4. Delta "thermostatic" worth it?
    By Bosun in forum Shower & bathtub Forum & Blog
    Last Post: 09-14-2007, 09:26 AM
  5. Delta Monitor 1700 (1768) "Graves" tub/shwr valve
    By holybuzz in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2007, 08:03 AM
