Results 1 to 3 of 3
Thread: type of p-trap for tub drain
    DIY Junior Member Brian Guinness's Avatar
    Jul 2013
    Maryland
    Default type of p-trap for tub drain
    Hi all,
    (apologies if this has been asked an answered, but i searched quite a bit)
    I'm in the midst of a bathroom remodel and am working on replacing the tub. I removed the old tub and the brass drain assembly, which connected to 1 1/2" PVC. I'm looking to put in an all-PVC drain assembly. Because of the way the drain pipe is angled, a p-trap with union joint (and union nut) is dry fitting much better than a p-trap that uses PVC cement to connect the two pieces - which was my first preference as I was more confident that it would never leak. But this cemented p-trap assembles top-to-bottom almost 1" higher and really throws everything off when connected to the drain pipe.
    So... is it OK and proper to use a p-trap with a union joint for a tub drain that i will have almost no access to once i drop the tub in? I'm a bit worried about the possibility of a leak, but am hoping that's just paranoia
    thanks!
    Brian
    Plumbing inspectors like to see a solvent weld p-trap.
    In forty years, I've never installed a p-trap for a tub or shower that had a union.
    Jul 2013
    Maryland
    Thank you, Terry, for the quick reply. It is what I expected. Now I just need to figure out how to get a solvent weld p-trap to fit!
  1. What Type Of Drain Pipe Is This & What 90 to Use
    By Hammerlane in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-01-2012, 06:28 PM
  2. Best drain type and strainer for kitchen sink?
    By TJanak in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2012, 04:46 PM
  3. P-Trap into floor drain? Or is that an S-Trap? (and not good)
    By bretm1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2011, 07:19 AM
  4. p trap type for shower drain
    By PJR in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2011, 04:32 PM
  5. What type of drain below hot water heater
    By spresco in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2009, 06:48 AM
