Results 1 to 4 of 4
Thread: Please explain Brine SLow Rinse cycle
    DIY Junior Member 14kbiz's Avatar
    Jun 2013
    NJ
    Default Please explain Brine SLow Rinse cycle
    My Autotrol 460i was not drawing up brine. My settings are 15 hardness, 24 capacity, and about 11 lbs salt. I called the dealer and he walked me thru a fix. Brine slow rinse seemed to be sucking air and I added more water to brine tank, he said level maybe low, so then the level was about 2 inches below the float, at least 6 -7 gallons in brine tank. Still sucking air, no water in glass window and ball not floating. Then he had me manually run Fast Rinse and said this would push any air out of the lines. I then manually went to brine slow rinse and it was working fine. Glass window was full, ball was floating and brine level was dropping. About half way thru the brine slow rinse cycle all brine was sucked from the brine tank and it seemed to start sucking air again. Glass window empty, ball not floating and sound like its sucking air. Water was coming out drain line and my water meter is turning so I assume it was rinsing. I never sat and watched a complete cycle. Is it normal to draw ALL the brine? And should I hear this sound of air be sucked in? Or could this be something in the brine line tube where the float is located?
    Fast Rinse seems to be working properly, rinsing resin and refilling brine tank. Brine now appears to be about half the level in was before which would make sense if my salt setting is 11 lbs and it refills about 3-4 gallons.
    Dec 2009
    Alaska
    I would say that it is time to replace the air check kit, AT1032416 as the ball is no long sealing like it should when the brine is done from the salt tank or the ring the ball sets on is damaged...
    The ball is what stops air from getting into the system when brine draw is done.
    Jun 2013
    NJ
    Thanks. Is it easy to change? Looks like one screw, do I have to depressurize the tank to change it?
    Dec 2009
    Alaska
    Should be simple, two screws in my book and undoing the brine line removal and replacing with new.
    For kicks I would start a cycle and put the unit in bypass , let the water stop flowing to the drain and change out the part.
    Better safe than start the change and fight a water spray...
  1. brine/slow rinse question
    By teve in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-22-2011, 08:41 AM
  2. What Causes the Brine Draw to be Very Slow in Water Softener?
    By Biddle in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-06-2011, 09:26 PM
  3. Clack WS-1 Leak during brine cycle?
    By tkramer in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-28-2010, 05:41 AM
  4. Culligan Medalist Softener Brine Refill Cycle
    By rbeachy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-27-2009, 03:39 AM
  5. Slow Brine fill on new Fleck 7000SXT
    By snortindog in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-09-2009, 02:36 PM
