Results 1 to 5 of 5
Thread: shower curb
    DIY Junior Member Carlosa's Avatar
    Mar 2014
    Texas
    Default shower curb
    Ok, i have everything ready for shower floor, installed pan liner on floor and over curb with dam corners and the metal lath over it but can i mortar it after i pour the floor or does it have to be done on the same day i pour the floor?
    Personally, I'd consider putting on the lath over the curb when putting in the pan's setting bed. The lath can help to tie the pan and the curb together if you use that technique. I like to form the lath into sort of a question mark shape, with a tail into the pan. The TCNA guidelines call for a reinforced mudbed. WHen you form the cup shape to fit over the curb, overbend it a little so it has a bit of spring to it, which helps to hold it in place. Only put fasteners low down on the outside - never any in the top or inside through the liner.
    Mar 2014
    Texas
    I got that part but can i mortar curb a different day?
    If you're going to make it out of deck mud (I'd suggest not!), then no, you should do it all at once. IF you're going to do it with brick mortar, that will stick to the deckmud and with the lath, bond things together, so doing them on different days shouldn't be an issue.
    Jul 2009
    North Vancouver, BC
    Default Make Sure you Flood Test that Shower
    Here is a nice illustration of a shower flood test with an inflatable test plug.
    Where did you source the dam corners. I went looking for some two weeks back here in Vancouver and after checking on 3 stores, calling four others found out none of the big plumbing suppliers even sell them! What a joke. Time to place another Noble order I think....
  1. Shower curb height
    By Carlosa in forum Shower & bathtub Forum & Blog
    Last Post: 03-31-2014, 06:30 AM
  2. shower curb
    Last Post: 03-09-2014, 12:06 PM
  3. Building-up an existing shower curb
    By SH140 in forum Shower & bathtub Forum & Blog
    Last Post: 11-27-2013, 08:51 PM
  4. how to handle shower curb
    By diyfun in forum Shower & bathtub Forum & Blog
    Last Post: 11-19-2013, 07:22 PM
  5. Lip/curb for a shower?
    By netrate in forum Shower & bathtub Forum & Blog
    Last Post: 09-02-2013, 10:54 AM
