Results 1 to 13 of 13
Thread: Washing machine drain layout
    DIY Junior Member 1832 farmhouse's Avatar
    Jul 2013
    Horsham , PA
    Default Washing machine drain layout
    Hello,
    This is my first post and I hope the pictures come through ok. I am DIYer with a wide knowledge of construction.
    I am moving laundry to 2nd floor while remodeling and want a extra eyes on my layout.
    I current setup is dryfitted together.
    thanks
    I can't see for sure, but does the vent go to the outside or is than an AAV? AAV venting may not be OK where you are.
    Aug 2009
    South*East
    Even if the AAV is permitted it must be in a location where it can be serviced.
    John
    Nov 2010
    Maine
    AAV's don't work on washing machine drains. Washer drains are a pressure assisted drain. AAV's only let air in, not out.
    Jul 2013
    Horsham , PA
    It is a AAV. I will have a access panel in front of it. I have never heard that AAV's could not be used on washing machines.
    I thought a AAV open and closes?
    would it not work with the pressure that washer machine discharges?
    I have had AAVs installed on previous piping in another home area in my on a drain line.
    Jul 2013
    Horsham , PA
    would anyone install a cleanout somewhere in my layout?
    Aug 2009
    South*East
    AAV's only open with a negative pressure.
    John
    Jul 2013
    Horsham , PA
    wouldn't there be negative pressure behind the water as it passes down the tee?
    Aug 2009
    South*East
    On a pumped drain such as a clothes there can be a positive pressure caused by the water displacing he air in the line. That will not allow the AAV open.
    John
    Jul 2013
    Horsham , PA
    I see. very bummed out right now. Things now means another roof penetration? do they make a vent for my situation that would exit through the wall ?
    Aug 2009
    South*East
    You could connect it to another vent in the attic.
    John
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    It might work according to this info . It talks about washing machines starting on page 19 and 27. You do need a vent in the system that vents to the outside.
    http://www.studor.net/documents/Stud...cal_Manual.pdf
    Nothing says you can't go through the wall and then up with a vent.
  1. Washing Machine Drain
    By Maddawg in forum Remodel Forum & Blog
    Last Post: 12-27-2012, 04:41 PM
  2. Washing machine drain tie in
    By phatman1969 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2011, 03:03 PM
  3. Washing Machine Drain?
    By Tire Boy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-06-2008, 09:32 AM
  4. Washing Machine drain
    By citykid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-20-2006, 07:05 PM
  5. Washing Machine Drain
    By LG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-14-2006, 07:20 PM
