Thread: From No Hot Water To No Water At All!!! Please Help!!
    DIY Junior Member Molly Mayhem's Avatar
    Jul 2013
    Pine Bush, NY
    Default From No Hot Water To No Water At All!!! Please Help!!
    Type of pump?
    Submersible____yes____
    Two wire (no control)___no_____
    Three wire (control box)___yes___
    Wire Size___18______ Wire Length_100+ ft._______
    or
    Jet Pump (above ground)_________
    One or two pipes down the well____
    Size of Pump?
    Motor Horsepower?__________
    Pump Model #______________
    Date Pump Installed__________
    Pumping from?
    Cistern tank___________
    Pond, lake, river________
    Water Well______yes______
    Depth of well____60 ft______
    Depth to water______5 ft___
    Pump Setting__________
    Pipe Size_________"
    Drop Pipe Material
    PVC____yes____
    Steel_______
    Poly________
    Well Recovery Rate___10____gpm
    Well Casing Diameter_______6”
    Rock Well______yes____ Sand Well__________ Other______________
    Date Well Drilled____1972________
    Well Casing Material
    PVC_____yes___ Steel_________ Other_________
    Pressure Tank?
    Bladder or diaphragm tank (one pipe to tank)____yes______
    Size or model of tank__SEARS Insulated Glasslined Vertical Water Storage Pressure Tank__________
    Air charge in top of tank, with pump off and water drained____________PSI
    (check with car tire gauge)
    or
    Plain Hydro Pneumatic tank (two pipes to tank, one in and one out)_________
    Size of tank________________
    Pressure Switch Setting?
    On 30, off 50 ________
    On 40, off 60_________
    Other_______________
    Pump Control Method?
    Cycle Stop Valve model #_________
    Variable speed control #__________
    Pump Start Relay (sprinkler timer, no tank)_maybe_________
    Manually turned on and off____________
    Pump Protection
    Cycle Sensor_________
    Pumptec_____________
    Low pressure cutoff switch (lever on side)__________
    Filters or Softeners_____no_________
    Before or after pressure tank_______
    Type of filter___________________
    Bypass available________________
    Water Used For?
    House Use____yes___ Number of baths___2____ Number of People___3_____
    High Flow Showers__no_____gpm?
    Plus/Or
    Irrigation with timers___no_____
    Irrigation with hoses__no______
    Heat Pump_no_____gpm?
    Problems Experienced
    No Water____yes_____________
    Water only part time________
    Water at all times but weak_____
    Air in water____yes___________
    Pressure surging___________
    Water Hammer (noise)______
    Too Much pressure_________
    Other_______________decline in hot water_____
    Pump makes clicking or buzzing sounds________
    No Sounds__________no sounds____
    Pressure gauge reading___50_____psi
    Other____________________________________
    Do you have, and know how to use
    an Ampmeter and Voltmeter___yesName:  water pump.jpg
Size:  37.9 KB_______________
    Describe Problem__________________________..... I have a submersible pump, and vertical hot water heater. For the last two weeks their was a lot air in my water line, spitting out in all lines, (shower, kitchen faucet, bathroom faucet, etc...). For the past three days I have had a decline in hot water, until (3rd day) their was only cold. Now I have no water at all!! I don't know what the problem is. I don't hear the tank filling up. My sub. pump is fairly new. If anybody has any suggestions; dealt with similar problem PLEASE HELP!!!
    Mar 2011
    Houston, TX
    Have you checked your breakers and breaker box connections ?
    You should keep the water heater off, until you can fill it with water, so it don't run dry.
    Good Luck.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    What are those loose wires for? They look like pump cable to me......
    Air in the pipes, sounds like a bad check valve in the pump, or a cracked/broken pipe in the well. Possibly a rotted fitting at the pump.
    Mar 2011
    Houston, TX
    Quote Originally Posted by craigpump View Post
    I was wondering the same thing, on the wiring.
    Looks like a Electric Heater was replaced with Gas.
    Looks unsafe to me no mater what they were/are used for.
    Maybe the poster will shed some light.
  1. Odor - Hot Water only (within a well-water, water softener system)
    By LeBlanc in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-31-2013, 06:49 PM
  2. Will Toto Drake/septic work with no grey water in toilet line to add water?
    By rgs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-11-2013, 02:43 AM
  3. Water Well Line - Sediment Filter - Expansion Tank - Water Softener - H2O Htr. Order?
    By chuck b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2011, 05:21 PM
  4. Water heater question - cold water, water leaking thru overflow pipe
    By jonyi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-26-2009, 01:26 PM
  5. Culligan mark 100 water softner water flowing to brine line all the time
    By seahawk99ca in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2007, 09:35 AM
