Results 1 to 5 of 5
Thread: removing iron deposits from piping
    DIY Junior Member jmmcgee57's Avatar
    Jul 2013
    pa.
    Question removing iron deposits from piping
    hello Everyone,
    I'm new to this so.......
    recently purchased new water softener system with h2o2 injection and reverse osmosis for particularly HARD well (56 grains of hardness)The water now tastes fantastic anf no longer smells of hydrogen sulphide.
    I went through my house and removed all screens and aerators from fixtures and what little I could see down the pipe it was pretty funky!!! brownish-slime in pipe wall much like one would see in a toilet tank with iron rich water.
    My question is this; since I am treating the water now I believe that over time this "slime" will dissipate.I am wondering if there might be a more proactive approach to cleaning the pipes without harming the system.
    Any and all comments will be greatly appreciated.
    jmmcgee57
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I would bypass any filter and allow the hydrogen peroxide to clean the pipes. I do this after installing a chlorine injection system. It works very well. Once you know the h2o2 has come through every faucet, hot and cold, put all filters back is service and runn the water until all the h2o2 is flushed out.
    Central Florida
    Don't forget the water heater. If the pipes are gunky, there's probably a foot of gunk in the bottom of the WH. Mine wouldn't even drain, so I replaced it and cut it open to see what it looked like. Gross.
    Also, you can circulate chlorine, or in extreme cases, I've heard of people circulating CLR through the pipes.
    Jan 2012
    California
    Chlorine tends to solidify the iron but will kill the bacteria. A bleaching and very thorough rinse should help. The softened water should clean the pipes over time but a simple vinegar recirculation cleaning, same as you would do for a tankless water heater should do wonders.
    Feb 2011
    NW Ontario, Canada
    If there is a drain cock in the line and you have a decent air compressor, you could inject air into the water stream and that should move some of it along without resorting to chemicals. Make sure to bypass the softener, remove aerators, and put a rag over the spouts to keep water from splashing everywhere.
  1. Cast iron piping
    By gman53 in forum Shower & bathtub Forum & Blog
    Last Post: 08-05-2012, 08:12 PM
  2. replacing galvanized/cast iron DVW piping... recommended?
    By seavlad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-03-2010, 02:41 PM
  3. Re-piping the main loop of a cast-iron radiator system
    By jmk823 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2009, 12:17 PM
  4. Removing Cast Iron Drain
    By jim.gary in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2009, 05:59 PM
  5. Muriatic Acid-Removing mineral deposits from glass
    By Mike50 in forum Remodel Forum & Blog
    Last Post: 04-29-2006, 03:30 PM
