Results 1 to 7 of 7
Thread: Honeywell WiFi Thermostat install help
    Default Honeywell WiFi Thermostat install help
    I have an older Honeywell thermostat (approx. 6 yrs. old) that I tried to replace with a new Honeywell RTH8580WF model. My current HVAC system is approx 6 yrs old as well (Lennox Signature Series). The current thermostat has a wire going to G, C, R, W1, W2, O. I was using the Alternate wiring key (heat pump system only) in the manual and the problem is that it says "If your old thermostat had separate Y1, W1 and W2 wires, check wifithermostat.com for help". I don't see anything there for help. Not sure what to do now...
    I have a furnace plenum and a heat pump. The plenum has auxiliary heat that kicks on when the heat pump cannot keep up. Can anyone shed some light on where the W1 and W2 wires go?
    Thanks.
    Mar 2011
    Houston, TX
    W1 will connect to W-O/B, and W2 will connect to W2-E/AUX.
    Then You need to setup the system type in the thermostat.
    Good Luck.
    Good Luck.
    Honeywell tech said to tape off the W1 as it is no longer needed. Have not gotten around to try it out. I am slightly afraid a miss wire will hurt the system.
    Mar 2011
    Houston, TX
    Quote Originally Posted by I26 View Post
    That sounds a bit strange because that would make it use AUX all of the time.
    I guess the Honeywell Tech should know, I was just going by the manual.
    It should not hurt to leave the wire disconnected, but kind of defeats the purpose of having a heat pump.
    Good Luck.
    DIY Junior Member javed's Avatar
    Jul 2013
    Brampton, Ontario.
    I have an older Thermostat Terminal connections as in the picture. How will I replace it with the newer ones?Name:  oldThermostat.jpg
    Mar 2011
    Houston, TX
    Quote Originally Posted by javed View Post
    Look up the model of the Honeywell that you have now.
    Then compare notes to the new one.
    And it may help to start a new thread, instead of adding to this one.
    Good luck.
    Jul 2013
    Brampton, Ontario.
    Can't figure out the black and the two white ones in the old one. How will I start the new thread?
  1. Mits 2 zone split - want wifi thermostat
    By rockycmt in forum HVAC Heating & Cooling
    Last Post: 04-25-2013, 01:50 PM
  2. WIFI thermostat - inexpensive solution for remote control
    By JerryR in forum HVAC Heating & Cooling
    Last Post: 10-29-2012, 06:06 PM
  3. Honeywell RTH7000 Thermostat
    By byrdman in forum HVAC Heating & Cooling
    Last Post: 10-18-2009, 03:34 AM
  4. Upgrading Honeywell Thermostat
    By TheOak in forum HVAC Heating & Cooling
    Last Post: 10-28-2008, 01:19 PM
  5. Looking for 2 stage honeywell thermostat
    By JOE1934 in forum HVAC Heating & Cooling
    Last Post: 04-06-2008, 12:30 PM
