Results 1 to 3 of 3
Thread: PP Crown Imperial interchangeable with Crown Imperial?
    DIY Member mc510's Avatar
    Dec 2009
    El Cerrito, CA
    Default PP Crown Imperial interchangeable with Crown Imperial?
    [EDIT - Please disregard my idiotic subject for this thread .... I mean to ask if Crown Imperial is interchangeable with Verve.]
    There's a Price Pfister 2-handle Crown Imperial set in my shower stall (installed around 1970 if that matters). I'm thinking about a rebuild kit to replace all of the replaceable parts and trim, but I can only find a 3-handle Crown Imperial kit, including diverter, and it's kind of expensive. Can I use a Verve 2-handle kit instead?
    If you do, you will have to replace the handles, escutcheons and, holder nipples because the Crown Jewel has a different set up. The Verve uses a longer stem, which is the reason for the change.
    Dec 2009
    El Cerrito, CA
    HJ, I want to replace everything that's in one of those Kissler kits, so I guess the question is if the rough-in valve body (being the only part that I wouldn't replace) is the same for all of the related trim styles?
    What's the "holder nipple"?
    If it matters, I've got Crown Imperial, not Crown Jewel.
  1. zoining my gas crown boiler
    By teva1991 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-23-2012, 07:02 AM
  2. Crown Aruba air blockage
    By Not Handy Mike in forum Boiler Forum
    Last Post: 02-06-2012, 11:56 AM
  3. Crown boiler aquastat
    By rotsa in forum HVAC Heating & Cooling
    Last Post: 01-04-2011, 10:13 AM
  4. Copper Sweat or Compression Fittings Metric to Imperial available?
    By Copper Bahamas in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-24-2010, 06:30 AM
  5. Metric faucet hose to imperial shut-off
    By dimskiy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2009, 01:01 AM
