Results 1 to 9 of 9
Thread: Urinal Flush Valves
    DIY Junior Member plumberj's Avatar
    Jul 2013
    NY
    Lightbulb Urinal Flush Valves
    I am looking to replace an existing manual flush valve which sits above an AS Washbrook urinal with a set of parts which include a sensor and a solenoid valve to control the water to flush the urinal - a kind of do it yourself automatic flush valve. Has anyone tried this before and if so what are the likely issues with codes? Basically I am looking to source parts from a home improvement store so I can swap out the manual valve.
    Thanks in advance for your thoughts!
    Aug 2009
    South*East
    What make valve do you have?
    John
    Jul 2013
    NY
    Hey John, it's a Sloane. So I want to remove that and replace with parts which include a sensor so I can effectively create my own automatic sensor-activated valve.
    Thanks.
    Jul 2013
    NY
    Thanks.
    Aug 2009
    South*East
    Here you go there a very easy retrofit.
    http://www.sloanvalve.com/Our_Produc...shometers.aspx
    Trying to build your own means fighting the certification agencies for both the plumbing bits and potentially, the electrical bits...much better to buy one that has already jumped those hurdles.
    Apr 2012
    New York, NY
    Especially when you can get a Sloan retrofit kit online for less than $250.
    Jul 2013
    NY
    Hi Jim,
    That's useful, thanks. You and johnjh2o1 and wjcandee all seem to agree on the retrofit approach and I can see the advantage of that in terms of it being pre-approved etc. which sounds sensible.
    Just to take it the full course, with a build-your-own version, which certification agencies would you need to speak with?
    Best.
    Electrical, UL, plumbing parts, take a look at the stickers on a stock valve in the store. A plumbing inspector could give you all sorts of grief (or not) if it's not something out of the box that has already been approved. To get those approvals is not inexpensive, and not something you'd likely want to do as a one-off. But, if you can build it out of parts that have already been approved, you have a chance with the inspector.
  1. Upgrade For 90 Degree Urinal Flush Valve?
    By PM5K in forum Toilet Forum discussions
    Last Post: 02-08-2013, 06:29 AM
  2. Sticky Mansfield 160 Flush Valves
    By wallskev in forum Toilet Forum discussions
    Last Post: 12-31-2012, 02:30 AM
  3. Third party 3" flush valves
    By wptski in forum Toilet Forum discussions
    Last Post: 11-10-2012, 04:48 PM
  4. Why I like Mansfield Flush Valves.
    By boyntonstu in forum Toilet Forum discussions
    Last Post: 08-04-2011, 01:31 PM
  5. Low flow urinal from American Standard and dual flush valve from Sloan.
    By Ivona in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2007, 07:26 AM
