Thread: Toilet to Septic tank issues
    DIY Member hygron's Avatar
    Jan 2010
    Hell Hole Swamp
    Default Toilet to Septic tank issues
    Recently we have experienced heavy rains for 2 months or so. The ground is saturated, and I am wondering?
    If water is not draining off after rains; Can that affect our toilet flushing due to septic tank being under water.
    Toilet is flushing as if there was a clog, but I believe there is "No clog". We have treated the toilet plumbing with a commercial drain opener, but after 2-3 days, and rain, it starts flushing slowly and "weezing", a bit.
    Any ideas?
    Aug 2009
    South*East
    If the ground is saturated around the septic system then that is the cause of your problems.
    John
    I've seen some installations where the septic is located on a higher piece of ground and it's pumped to that location.
    If your ground water has filled the lines where it is, it's going to be slow going. You must have a gravity system.
    I need to add that forum you were mentioning too.
    Jan 2010
    Hell Hole Swamp
    Thanks. That is what I thought it could be.
    Yup. Gravity system with drain field.
    Great news about forum. IN fact; I have been checking for it!
  1. Septic Tank Elimination: Does it make sense to install new toilet drain pipe?
    By amateur plumber in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2011, 11:52 AM
  2. Which Low Flow toilet would be best for a septic tank?
    By JC101 in forum Toilet Forum discussions
    Last Post: 05-31-2011, 03:39 PM
  3. Does a septic tank and well water affect the type of toilet I buy?
    By sobersgea in forum Toilet Forum discussions
    Last Post: 02-28-2010, 01:49 PM
  4. Septic gas belching past full p-traps/ Septic tank drainfield failing? Venting issue?
    By ryan100 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2008, 06:49 PM
  5. septic issues
    By J.B. MacDonnchadh in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2005, 10:33 AM
