Results 1 to 4 of 4
Thread: 1 1/2" Bathroom Sink Drain
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default 1 1/2" Bathroom Sink Drain
    Is there any benefits on using a larger sink drain "1 1/2" for the bathroom sink......obviously on the inlet, there is a 1 1/2-1 1/14 nut on it.
    It's always the sink stopper/drain that is the culprit on slowing down the flow
    I don't know where you would find a 1 1/2" lavatory drain, unless it was a special order. But, there would be no benefit, since the annular opening under the stopper is a lot smaller than the 1 1/4" tubing.
    Jun 2006
    Standard 1 1/4
    1 1/2 Trap with the downsizer nut on the trap 1 1/2 to 1 1/4
    It is how I usually do it, but only because that lets you drop the tailpiece further into the trap, making an easier connection process.
  1. Can bath sink and utility sink drain into 1.5"...PHOTOS
    By Hammerlane in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2012, 01:02 PM
  2. Help!!! Single Bathroom sink to Dual bathroom sink drain
    By JayJay18 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-28-2012, 09:31 AM
  3. What are you gents doing to get rid of "Gnats" Fruit Flies coming out of Sink/Drain?
    By 87vertgt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-26-2009, 12:01 PM
  4. Looking for "thin" ADA bathroom sink
    By reny90077 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2009, 09:16 AM
  5. Bathroom Sink "Gurgling"
    By nin28 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-20-2008, 09:25 PM
