Results 1 to 10 of 10
Thread: Need Advice on water softener Installation
    DIY Junior Member ra's Avatar
    Jul 2013
    Manitoba
    Default Need Advice on water softener Installation
    Hi There,
    Can anybody help me out on my water softener installation.
    I`m looking to install my water softener to my house plumbing and your suggestions are very much valuable.
    Can somebody look at the attached picture and give me the list what i need to buy for plumbing the softener to the water line.
    I am mechanically inclined but do not know much on the plumbing side.
    I believe it is not a difficult task.
    Thanks.
    Nov 2010
    Maine
    Is that really the main water service to your home?
    Jul 2013
    Manitoba
    Yes, it is the main line from city.
    The size is 3/4" and the line for yard is 1/2"
    Jan 2012
    California
    The valve is a 5800 series, we need to see the bypass/plumbing connectr to know for sure what you need. I would recommend the falcon John Guest x 3/4" FIP connector if your valve has the 60049 bypass and 18706-02 3/4" plumbing connector. Name:  jg.jpg
    Jul 2013
    Manitoba
    Thanks for your reply Dittohead,
    Hope the picture below helps you to know more about the connection.
    Jul 2013
    Manitoba
    And also see the 3/4" SS by-pass valve that i will be usingName:  11BJbL6-WLL.jpg
Size:  3.5 KBName:  41AVbpXIreL.jpg
    Jan 2012
    California
    The SS bypass is very high quality and will last for decades. If you use the Falcon 3/4" x john guest flexible adapter, a stainless steel 3/4" nipple is cheap and will convert the FIP threads to an MIP thread that will attach properly to the Falcon Flex line. http://www.freshwatersystems.com/p-7...-fip-x-18.aspx this is a good source for this item. http://www.mcmaster.com/#catalog/119/6/=ngr3kj part# 4830K193 is the stainless steel nipples you would use.
    Hope this helps!
    Any other suggestions from the real plumbers? I am a certified installer with the WQA and a C-55 contractor, but I am always open to the ideas of guys who do real plumbing for a living every day.
    Dont forget the drain line, just use 1/2" PVC, it is a non pressurized line. Be sure to install a proper air-gap. Test your incoming water pressure to. Do not exceed 80 PSI (UPC 608.2).
    Nov 2010
    Maine
    I'm not real happy with the 3/4" pex. It and the fittings are restrictive as hell. I'm afraid the flow may suck
    Jan 2012
    California
    Code allows for higher velocity in pex than in copper but... we get calls constantly from people having problems with restricted flow in new houses that have pex. Mainly the showers and bathrooms farthest from the feed pipe. Pex can be run in smaller piping according to code, but some engineers and planners are not taking the frictional losses into account properly or they are under engineering the pipe size to save a few bucks. If I am not mistaken, 12FPS is considered acceptable for Pex, copper is rated for 8 FPS. That is a significant difference. Personally, I will stick with my copper plumbing.
    Jul 2013
    Manitoba
    Thanks for all your inputs,
    Now i have successfully installed the Softener, but i need your help to program the softener.
    I have the manual it came with it but it`s not that clear.
    Can anybody guide me from the start up as if to plug in the unit and starting at first time.
    your help is greatly appreciated Pro`s,
  1. Water softener installation mistakes
    By socalal in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-23-2011, 11:32 AM
  2. Water Softener Installation?
    By prickett in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-18-2011, 07:53 AM
  3. Water Softener Self installation
    By chubyball in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-03-2009, 12:12 PM
  4. Water Softener CPVC Installation
    By tunarle in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-29-2009, 08:43 PM
  5. installation of a water softener
    By Greg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-08-2005, 07:41 PM
