Results 1 to 3 of 3
Thread: Delta R10000-UNWS Valve
    DIY Member SH140's Avatar
    Jan 2013
    Vallejo, Ca.
    Default Delta R10000-UNWS Valve
    I've installed this Delta valve in shower/tub. It comes with a square plastic piece called a plasterguard (#RP46075) that snaps into place. I assume it's purpose is to allow proper placement (depth) of valve in relation to the finished wall.
    My question is whether this piece stays on the valve after tiling, or are you supposed to remove it before you install trim kit?
    Normally, unless you're using the thin wall installation (i.e., say a fiberglass one-piece), there's no reason to keep the thing in place after you've got it positioned properly (well, it will help keep thinset, etc. out of the trim mounting holes, so you could leave it a bit longer). I HIGHLY recommend you temporarily install the trim and then get the valve set at a depth YOU like. If it's installed between the min/max marks, the trim will fit, but YOU may not like the way it looks. To the manufacturer, if it fits, it's okay, but that isn't necessarily what you want...mock it up first!
    Jan 2013
    Vallejo, Ca.
    Damn....I shoulda asked the question BEFORE I soldered everything into place. Ah well, it still will look 1000% better than before I started the re-model. I can use this tip for the second bath project coming up. [It's kind of funny, this one of the times I actually read the directions and followed them before I started. Usually it's afterwards, when something goes wrong.....That sound you hear is me slapping my forehead]
  1. Delta R10000-UNBXHF Multichoice Universal Shower Only Valve Body
    By themp in forum Shower & bathtub Forum & Blog
    Last Post: 03-13-2013, 04:29 PM
  2. Delta MultiChoice Universal valve body (R10000) and length of drop to spout
    By johnny-canuck in forum Shower & bathtub Forum & Blog
    Last Post: 06-03-2012, 04:27 PM
  3. Delta R10000 rough in valve questions and more
    By Finch85 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2012, 09:56 AM
  4. Delta MultiChoice, R10000-UNWS
    By mdsnj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2010, 06:38 PM
  5. cartridge for Delta R10000-UNWS valve
    By Joe Mc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-30-2008, 04:45 PM
