Results 1 to 5 of 5
Thread: Brine Tank Refill
    DIY Junior Member cap33905's Avatar
    Jul 2013
    Florida
    Default Brine Tank Refill
    I have a 8x44 tank with a Fleck 5600 metered valve on it, and my question has to do with the brine tank refill cycle. My salt dose setting is set at 9lbs, and from what I have found in my research is that 3 gallons of water should be going back into the brine tank during the brine refill cycle. My brine tank has almost 6 gallons of water in it. Is this acceptable or too much? Will it cause me to use more salt? What could be the cause of it? (I just replaced the piston, seals and spacers, and replace the brine injector parts last June)
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Does the brine tank have a grid plate? If so, you will have more water but all of it will not be draw out during the brine cycle.
    Jul 2013
    Florida
    There is no grid plate, just the tube that the supply line is in, and salt.
    Nov 2010
    Ocala, Florida
    Have you disconnected the brine line from the valve while the unit is in service to see if it is dripping. The only other cause would be if the brine cam did not match the brine flow control. With the 5600, they change the brine cam (sticker I think) to match the brine flow control. If the brine flow control is .25, the cam salt sticker will be max 36 #. If it has a .5 brine flow control, then the sticker max is 18 # IIRC.
    Jan 2012
    California
    http://www.pentairwatertreatment.com...rine%20Cam.pdf
    This bulletin expalins in detail the flow control/brine cam issue.
    Be sure that your brine cam sticker matches the BLFC button. It is common for some service technicians to not know the difference. If they replace the powerhead or the drain line/brine line assembly, these can easily get mis-matched.
  1. AquaPure AWS200M brine tank refill?
    By Christopher Piper in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-19-2012, 05:30 PM
  2. Need Some Help Please: Control Valve Doesn't Shut Off Brine Tank Refill
    By Biddle in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-22-2011, 04:18 PM
  3. Brine refill problem
    By PatSea in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-23-2010, 06:57 PM
  4. cole and massey PIX 34 brine refill not working
    By evanm in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-25-2010, 11:13 AM
  5. Culligan Medalist Softener Brine Refill Cycle
    By rbeachy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-27-2009, 03:39 AM
