Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: can't get drain out for new garbage disposal
  1. #16
    That was also my first thought when he said "saw" of any kind. He took a fairly easy job and turned it into a project.
  2. #17
    Just so more people know, the old fashioned hack saw will work in many cases. It does less damage.
    A flat blade screw driver and a hammer may have worked to spin the flat part around too. Just tap, tap, tap and around it goes.
    Also, no Tape on those sink connections. Water supplies come "with" rubber cone washers. All the tape does is get between that seal, and make the threads harder to run down and make tight.
    I know the flunky at the home center likes to sell tape, but it's almost never, ever needed.
    A big part of my job is taking everything apart, removing all the tape and putting it back together clean.
  3. #18
    DIY Junior Member tim123's Avatar
    Jul 2013
    Florida
    Yea, tap tap tap didn't work. The pieces were fused by rust.
    Thanks for the tape info...
  4. #19
    tap, tap, tap, is what a shoemaker does. You needed to bang, bang, bang. So far, I have never had to cut a disposer mount loose.
  5. #20
    hj, most plumbers have pliers with them, which they can use to pry off the plate.
    A homeowner often does't have what I call normal tools.
    I can't think of any plumber taking more than a few seconds to pull that plate off.
  6. #21
    The plate just slides down down, so even a screwdriver would have pried it loose from the sink. It was not bound by corrosion.
  7. #22
    Mar 2011
    Houston, TX
    So I guess PB Blaster don't work ?
    What a bummer. Guess I need a sawzall.
    Have Fun Everyone.
  8. #23
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Exclamation
    Quote Originally Posted by terry View Post
    A homeowner often does't have what i call normal tools.
    yes I agree Terry i would have that ring off and installing new one then you can say ouch !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  9. #24
    Feb 2011
    NW Ontario, Canada
    tap, tap, tap, is what a shoemaker does...
    ROFLMFAO
    I have a BFH and a 36" pipe wrench that could twist that puppy off.
  10. #25
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by tim123 View Post
    I didn't mention that I am in the middle of a kitchen remodel, which makes this a particular pain in the ass as I will have to replace the sink again whenever I get around to the new counter (undermount).
    c'est la vie.
    If you were planning to put in a new sink they why not just leave it alone until then?
  1. double sink shooting water up thru drain when garbage disposal is on
    By gwheels16 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-13-2011, 09:13 PM
  2. Drain for garbage disposal
    By MattE in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-24-2009, 08:40 AM
  3. washer/garbage disposal drain
    By SRICE1417 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2009, 01:18 PM
  4. Drain from Garbage Disposal
    By RPO in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2007, 04:53 AM
  5. Garbage Disposal drain/waste pipes
    By Bobbi B in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2006, 10:44 AM
