Results 1 to 5 of 5
Thread: Best Connection Method for PE pipe to rigid PVC?
    DIY Junior Member Dennis47's Avatar
    Jul 2013
    Arizona
    Default Best Connection Method for PE pipe to rigid PVC?
    My first post. Our 35 yr old house is built on a rocky slope and has a black flexible water line, probably polyethylene (PE), from the meter to the house (about 100 ft.). We had the shut-off valve at the house end replaced last month and the plumber double-clamped the poly pipe over a Sch 80 PVC nipple threaded into the valve. This connection is in shallow dry well in the patio slab, and the end of the poly just barely makes it past the well wall so there isn't much to work with. The new connection is already leaking past the clamps. The system is under about 80 pound pressure. Before the new valve installation, the poly connection was tight and dry. Seems to me there must a better method for making this connection that I can ask the plumber to use; perhaps a compression-type fitting. Suggestions?
    A "barb fitting" is the proper thing to insert, NOT a "smooth" sch. 80 nipple.
    Jul 2013
    Arizona
    With hose clamps? Is that all I need?
    It should have a barbed fitting and two hose clamps.
    I like brass, though those are normally only getable at a plumbing supply.
    The box stores are too cheap to carry what the plumbers use.
    Connecting poly with a barbed fitting requires some space to work with. Sometimes a union is handy in a tight space.
    Jul 2013
    Arizona
    Plumber hasn't come back yet; I reported the leak Monday. I'll ask him to replace the PVC fitting with a brass barb if he can. My concern is that if he has to cut the nipple out of the poly, he'll have to break up the patio slab to get to a new clean end. Would you add the union on the rigid side just to gain some working room?
  1. Rigid faucet supply line connection
    By mookie3333 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-13-2011, 04:40 AM
  2. Method to keep irrigation pipe above lake floor
    By cory2605 in forum Irrigation / Sprinkler Forum
    Last Post: 06-19-2009, 09:16 AM
  3. PE Pipe Connection
    By Duke76 in forum Irrigation / Sprinkler Forum
    Last Post: 05-18-2009, 11:35 AM
  4. Long flex metal conduit instead of rigid pipe?
    By electrotuko in forum Electrical Forum discussion & Blog
    Last Post: 06-18-2008, 07:01 PM
  5. Flex or rigid connection to water heater
    By jonb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-18-2005, 07:39 AM
