Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: No clogs? Toto Drake Sanigloss?
  1. #16
    DIY Junior Member matryoshka's Avatar
    Jul 2013
    Massachusetts
    Okay, one more question... I think I read that with the G-Max flush, if you hold the lever down longer, it will add more water if it's needed for, um, extra flushing. Is that true, and if so, does the Double Cyclone also work that way?
  2. #17
    Apr 2012
    New York, NY
    Yes. And yes. You can also substitute the flapper that's in there with an adjustable one that would let you, if necessary, put more water into the flush cycle. If that becomes necessary, Toto will deny it but come back here and we will tell you what to do.
    Generally, though, adding water to the cycle doesn't do that much in terms of waste removal, as I discovered trying to hold the handle down with my stupid Portrait toilet. It just ran more water in behind the clogged waste and filled the bowl. The key is to have a properly-sized and properly-designed trapway, which Toto does.
  1. Is There a Drake 2 Round Bowl 1.28 with Double Cyclone/Sanigloss?
    By jmbluv999 in forum Toilet Forum discussions
    Last Post: 05-26-2012, 10:33 PM
  2. Is Sanigloss Finish Available on Toto Drake ADA Height?
    By jmeloney in forum Toilet Forum discussions
    Last Post: 03-19-2008, 05:23 PM
  3. Toto Drake, ADA, Sanigloss
    By emmvee in forum Toilet Forum discussions
    Last Post: 10-06-2007, 11:32 PM
  4. Drake - How important is sanigloss?
    By NickG in forum Toilet Forum discussions
    Last Post: 01-25-2006, 08:50 PM
  5. Toto Drake with Sanigloss--only in white?
    By RBKM in forum Toilet Forum discussions
    Last Post: 11-03-2005, 02:22 PM
