Results 1 to 5 of 5
Thread: recessed tile shelf in shower
    DIY Junior Member melt's Avatar
    Jul 2013
    St. Louis, MO
    Default recessed tile shelf in shower
    We recently had a bathroom put in our basement. We had the "contractor" (not on speaking terms now as he just kind of disappeared) put in a recessed tiled shelf in the shower. We now have noticed the grout separating from the tile around the edge of the shelf. And it looks like the water is seeping down to the drywall. My question is where do we start? Since the original guy is Mia, do I call a plumber? So distraught over the whole basement anyway as we had water damage awhile ago. Looking for some advice please!
    Oct 2011
    Quote Originally Posted by melt View Post
    If drywall was used as the backer then that is not a proper install.
    Call a tile setter.
    DIY Junior Member John28's Avatar
    Mar 2013
    PA
    Was the niche constructed or of the tilable type? Just curious as I just recently installed my first traditional shower and niche, and had no issues, and I'm a rookie. The only seem on a tileable type is where it meets the wall, if anchored and properly sealed, it shouldn't leak. Where a construced one takes more care as all seems need sealed. Again coming from a rookie, sounds as if it was not properly anchored/supported, allowing movement in the niche where the joint is, causing seperation? And this joint should have some type of antifracture membrane, with a waterproofing applied to it? Hard to say, not knowing the the underneath construction? I used a tilable niche, which has a seem at the backerboard, properly anchored niche, filled gap with Hydroban, applied anti-fracture tape with skim of Hydroban, then applied Hydroban to all backerboard, so far no problems.
    If the guy used drywall in that shower and there's only one technique that has an approved method that allows it (Schluter's Kerdi membrane shower system), your shower was not constructed properly. It's hard to predict how long it will last. People tend to think that tile is waterproof in a shower...in reality, a properly built shower is water tight before the tile is installed. The tile is a decorative and wear layer, not the waterproofing layer! Cracking grout is an indication of movement. Whatever is behind the tile has absorbed moisture and is swelling, or it was just not built strong enough, and there's movement from that (much more likely from what you've indicated that it's the former rather than the later, but it could be both).
    DIY Junior Member SJ-JT's Avatar
    Jul 2013
    NJ
    There is a site run by John Bridge - his name followed by .com - that may be extremely useful for you. From what I've read there jadnashua's comment above is exactly correct. (I see he's been to a Schluter workshop, too.) You can get advice on the john bridge site. How the heck one find's skillful, honest tradespeople/companies I still don't know. I've paid a lot and I've paid not so much. Have had some very satisfactory work done for decent prices and some awful work done for quite high prices.
  1. Recessed light can located next to rain shower plumbing
    By ken.yong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-24-2011, 06:48 AM
  2. Recessed lighting and vent fan in shower
    By fatalbie in forum Electrical Forum discussion & Blog
    Last Post: 12-19-2009, 02:46 PM
  3. Halo recessed light and shower trim......
    By chrisexv6 in forum Electrical Forum discussion & Blog
    Last Post: 03-17-2009, 06:52 AM
  4. Recessed light over shower
    By Magicrat in forum Electrical Forum discussion & Blog
    Last Post: 12-30-2008, 03:00 PM
  5. corner shelf in shower
    By Wallace 49 in forum Shower & bathtub Forum & Blog
    Last Post: 12-10-2006, 06:25 AM
