Results 1 to 5 of 5
Thread: Need washer & sink plumbing setup advice.
    DIY Junior Member AnthonyC's Avatar
    Jul 2013
    Honolulu
    Default Need washer & sink plumbing setup advice.
    I have been searching high and low for info on how to setup plumbing for a washer and sink and finally found this drawing on this site. The diagram is close to what I need except my sink is on the left side and the washer is on the right.
    Base on this diagram, can I run the sink drain below the washer drain or run the washer drain directly to the vent and add a new vent above 42" to the sink drain instead? Reason for asking is to avoid cutting too many holes on the wall stubs.
    More like this?
    Jul 2013
    Honolulu
    Thanks! That's perfect. --
    Oops spoke to soon. Here's the issue I having.
    The vent line is about 7 feet to the right side of where my sink and washer are. From your picture, I can't get the sink drain line to the sink inside the 4" wall. I can run the drain line outside of the wall but was hoping to hide all the pipes.
    Issue -
    Will this work?
    DIY Junior Member John28's Avatar
    Mar 2013
    PA
    Quote Originally Posted by AnthonyC View Post
    Will this work?
    Not sure if you'd should tie the sink drain in below the standpipe? Probably above?
    Mar 2013
    PA
    What was the outcome?
  1. Please look at my washing machine/utility sink drain setup...need advice.
    By Dave88LX in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-15-2013, 03:36 AM
  2. Proper Drain / vent setup for Dish Washer
    By jamiedolan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-09-2009, 08:49 AM
  3. Motor setup advice
    By joeyar in forum Electrical Forum discussion & Blog
    Last Post: 01-12-2008, 09:32 PM
  4. Need Well Pump Setup Advice
    By chetwynd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-07-2007, 12:49 PM
  5. Leaky Utility Sink / Odd Setup for Washer
    By sirih in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-10-2007, 10:51 AM
