Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Collapsed casing? Any solutions?
    DIY Junior Member MarkMCM's Avatar
    Dec 2010
    Arlington, TX
    Default Collapsed casing? Any solutions?
    4" pvc cased well.
    200' deep
    static water level 60'
    well is approximately 30 years old.
    Old pump went out and was unable to be pulled, pvc broke at pump. Pump is at the bottom of the well.
    New pump will not go past 100'.
    Well is really unusable due to decreased available water. We have gotten a camera and a spear past the constriction.
    Are there any solutions other than drilling a new well? The two well guys that have been out don't offer anything other than a new hole.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    My first question is what caused the casing to collapse?
    Did the pump guys try to get a 3" Grundfos pump past the tight spot?
    Dec 2010
    Arlington, TX
    Thanks for the reply. The consensus on the casing problem seems to be minor earthquake activity in the area.
    Nobody mentioned a 3" pump. Could we pull the present pump and use a 3" diameter weight to assess clearance?
    Apr 2012
    ct
    Yep, I would try a weight 3" in diameter before I bought the 3" pump just to be sure. You might find a pump guy who has a used one you could try too.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    After re-reading your post, I think a 3" pump would probably be the solution. Have your well guy blow the well to see what it makes. I would look for at least 10 GPM before I would mess with the old well, and if it makes any sand or sediment then scrap it.
    Good luck.
    Dec 2010
    Arlington, TX
    Thanks guys.
    We tried a 3" weighted pipe and got it past the constriction and then...
    We got the new 3" pump (Grundfos 10SQ10-290) to depth and we are back to original flow. That is the good news.
    Bad news. The Pumptec, after running for 5 minutes or so, shows Load and Voltage lights flashing, denoting a "rapid cycle".
    What gives? My well guy says, "Pumptecs don't work on 3"pumps." and "Those 3" pumps don't last very long anyway."
    I find both of those statements hard to believe. HELP! We need to get the Pumptec back in-line.
    Apr 2012
    ct
    Pump Teks and 3" Grundfos pumps are not compatible, remove the Pump Tek.
    Those little Grundfos pumps are pretty good units, I have seen some go 10 plus years.
    Don't let it run dry.
    Dec 2010
    Arlington, TX
    Any suggestions on pump protection? We have a low pressure cutoff on the line now.
    Apr 2012
    ct
    I don't think there is anything like a Pump Tek for the 3" Grundfos.
    Dec 2010
    Arlington, TX
    Thanks. I guess we'll see how things go with the low pressure cutoff.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by craigpump View Post
    What about a Cycle Sensor?
    http://www.cyclestopvalves.com/prod_sensor.html
    Dec 2010
    Arlington, TX
    Anxious to hear the answer to this one.
    Apr 2012
    ct
    Ask valveman
    Feb 2011
    NW Ontario, Canada
    Ask valveman
    I tried pinging him but he appears to be offline now.
    Moderator valveman's Avatar
    Mar 2006
    Sorry. Traveling. Cycle Sensor works fine with SQ.
  1. Replies: 5
    Last Post: 01-18-2013, 10:38 AM
  2. solutions for a very small bathroom
    By calvin in forum Toilet Forum discussions
    Last Post: 07-28-2011, 08:28 AM
  3. Delta and Tankless HWH Solutions
    By Greatwhitewing in forum Shower & bathtub Forum & Blog
    Last Post: 04-20-2011, 02:18 PM
  4. Domestic hot water not consistently hot.... Solutions?
    By woodslanding in forum Boiler Forum
    Last Post: 01-11-2011, 10:43 PM
  5. Shower Valve Put in Wrong--Solutions??
    By smcgowan65 in forum Shower & bathtub Forum & Blog
    Last Post: 10-21-2005, 07:15 AM
