Results 1 to 3 of 3
Thread: Cottage heat choices
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default Cottage heat choices
    800 sq ft northern Michigan cottage. Trying to decide on 9 baseboard heaters controlled by 3 thermostats, or one central electrical furnace unit. Ducts have to go thru uninsulated attic above insulation or below in crawl space. Cottage built on post beam joist design like a deck. What's more cheaper to run? Lose too much heat thru cold attic or crawl? Used 8 months year, not in coldest part of winter. Thanks. Have Cadet baseboards on hand. Appreciate advice. Don't want to use propane, no natural gas available.
    Minisplit heating/air-conditioning units with several heads is probably way more efficient, and would give you a/c for those days you might want it. SOme might have trouble on your coldest days, but still can work in many locations. That may not be a big issue, except for potentially keeping it above freezing in the winter when not occupied (then, you'd probably want to winterize it, and then wouldn't care so you could shut everything off). On these, one watt in can produce 3-4W of heat, much more efficient than resistance heating, and they're efficient should you want cooling as well. These things have gotten much better in the last 5-10 years, and are a good choice many places where they weren't before.
    Nov 2010
    Maine
    Electric baseboard or a monitor kerosene heater.
  1. Toilet Choices?
    By ncage1974 in forum Toilet Forum discussions
    Last Post: 10-05-2013, 11:33 PM
  2. Using Cable Electric Heat as a primary heat source in your bathroom (Heat Loss Calc)
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 08-25-2012, 05:02 PM
  3. Garbage Disposal Choices
    By JThiessen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-03-2011, 11:26 PM
  4. Hot Water Recirculation Choices
    By curtisjo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2010, 05:17 AM
  5. What are my choices with 13 3/4 rough in?
    By moneypitowner in forum Toilet Forum discussions
    Last Post: 11-15-2009, 09:04 AM
