Results 1 to 9 of 9
Thread: electric water heater: no drain valve??
    DIY Junior Member gramps's Avatar
    Jan 2009
    Ontario
    Default electric water heater: no drain valve??
    I need to replace my 25 year old Rheeem electric water heater. naturally i would have to drain it first, but there is an odd situation that is preventing me.
    as you can see from the photo, there is no tap for draining it.
    At the top of the unit are 3 plastic covers. maybe there is pressure relief value under those plastic covers, but how would you drian this?
    I was planning on maybe doing the job myself properly.
    -g
    Feb 2011
    NW Ontario, Canada
    Obviously a non-standard install. It looks like the drain port was used for either the cold entry or a recirc line. The TPR if that is what is shown, is in the wrong place and would not sense a high temp.
    Remove the lower element and screw a hose bib in its stead to drain it.
    Jan 2009
    Ontario
    to remove the element, doesn't the unit have to be drained first?
    Feb 2011
    NW Ontario, Canada
    I would not have suggested it if that were the case. Elements are very often replaced without draining the tank.
    They made your job hard.
    Like mentioned above, the drain was removed.
    If you keep all the taps closed, you can cut the copper pipe and slip on a sharkbite hosebib that will allow a hose connection.
    You will need to shut off the water supply first.
    By keeping everything closed, the water will drain very slowly, allowing some time to cut and push on the hosebib.
    It's like holding you thumb on top of a straw. The tank will be slow to drain if no air can replace the water as it drains.
    Jan 2009
    Ontario
    if quickly put on a sharkbite, the water wont gush out quickly at first? i don't understand the purpose of removing the lower element if this is the method.
    Feb 2011
    NW Ontario, Canada
    Terry and I gave two different options. If you cut the pipe like Terry suggests, then don't remove the lower element. If you cut the pipe you will get water from the top section of pipe so be prepared to catch it or quickly plug it.
    Aug 2009
    South*East
    Remove the relief valve and screw in a hose bib in its place that will allow you to drain most of the water.
    John
    FWIW, do NOT replicate the install you have! A T&P valve needs to be installed on the hot outlet or the special port near the top of the tank provided for it.
  1. Grounding Whirlpool Tub Motor and Heater - Bonding Panel to Electric Water Heater
    By chuck b in forum Electrical Forum discussion & Blog
    Last Post: 02-06-2012, 09:01 AM
  2. Water Heater Drain Valve
    By Craig99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-09-2010, 12:33 AM
  3. water heater t&p valve drain lines
    By jcm55 in forum Solar and Geothermal Water Heating Forum
    Last Post: 11-18-2007, 03:50 PM
  4. Leaking Drain valve on Water heater
    By Pargmark in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-20-2007, 07:51 PM
  5. Hot Water Heater drain valve
    By white tiger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-25-2005, 01:03 PM
