Results 1 to 3 of 3
Thread: Recessed fixture problem
    Default Recessed fixture problem
    Hello. The pictured recessed fixture decided to drop slightly out of the ceiling. It might have been held in previously with a paint film (I cleaned up the paint edge a bit before taking the photos), but is not tight to the ceiling currently. Are there clips that I can reset/tighten on this? How do I take it apart? I would think the trim piece would pull down or pop off but I can't get it to move--the whole can just floats around in the ceiling. Thanks.
    I figured out how to snap the trim off to get access to the retaining clips. I need a couple of new clips (might be lightolier part 1955). Anybody know if there is an equivalent/generic part available at the hardware store?
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    If the can is down you should be able to turn the clips back into position. If they are bent back too far you can just bend them back in.
  1. Semi-recessed vessel sink - with overflow? Milforde Semi-Recessed Porcelain Sink
    By blecrone in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-29-2012, 04:08 PM
  2. Help with recessed flange.
    By SugarHollow in forum Toilet Forum discussions
    Last Post: 01-26-2010, 08:51 PM
  3. Recessed Light 1 to 6?
    By coopns in forum Electrical Forum discussion & Blog
    Last Post: 06-17-2008, 08:44 AM
  4. Flange Recessed
    By glennmanus in forum Toilet Forum discussions
    Last Post: 06-28-2006, 09:57 AM
  5. recessed radiator
    By pachai in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-03-2006, 02:17 PM
