Thread: Supply to Boiler and pressure reducing valve question
    DIY Member philtrap's Avatar
    Jun 2013
    Long Island, NY
    Default Supply to Boiler and pressure reducing valve question
    Referencing the attached photo from the Installation Manual for the TT 100 solo, I have a question about the pressure reducing valve. It shows (unless I'm reading it wrong) the pressure relief valve looped around a ball valve. When the ball valve is closed, the water would be supplied at a reduced pressure by the reducing valve which is OK. My question is since I've never seen an installation like this:
    1) Is the reason for the ball valve so that you can fill up the system quickly without going through the reducing valve?
    2) Is the ball valve necessary?
    Name:  Prestige 110 TriMax-User Page 21.jpg
    Nov 2010
    Maine
    You don't need the bypass valve. The prv has a quick fill feature built in.
    Default valve
    1. YEs. 2. Only if you want to be able to fill and flush rapidly. 3. I usually pipe the bypass around the reducing valve, but that is just a personal preference and has nothing to do with how it works. 4. Not all fill valves have the internal bypass/quick fill feature
    Jun 2013
    Long Island, NY
    Thanks guys!!!
  1. Pressure reducing valve
    By noderman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-16-2013, 07:45 PM
  2. Pressure Reducing Valve: Bad?
    By JohnnyO in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2013, 12:46 PM
  3. Could my new pressure balance valve be reducing my water pressure?
    By JenJen in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2011, 06:57 PM
  4. pressure reducing valve
    By duffers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2007, 05:45 PM
  5. Pressure Reducing Valve Noise
    By tomtheguvnor in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2007, 04:31 PM
