Results 1 to 3 of 3
Thread: PVC coupling question
    DIY Junior Member gtfrueh's Avatar
    Jun 2013
    PA
    Default PVC coupling question
    Hello,
    I need to couple two pieces of 1-1/2" PVC pipes together, but I need it to also be strong. I bought the standard fitting at Home Depot, but the total length of the fitting is 2-1/2 inches. I can only slide the PVC pipe into the fitting about 1-1/4 inches. I don't think this will provide the strength I need.
    Is there a 1-1/2" fitting that is longer than 2-1/2 inches? Even a few inches on either side would be good.
    Thanks,
    George
    Yakima WA
    The standard fitting will be plenty strong. You must understand that PVC is not technically "glued". The so-called glue or cement is actually a solvent that liquifies the surfaces of the pipe and fitting for a few seconds. The allows the pipe of fully engage the fitting. The liquified surfaces blend together and form a chemical weld. The resulting joint is permanent and as strong or stronger than the rest of the pipe.
    Aug 2009
    South*East
    If your use is just for the strength you could use a coupling that's used for water lines. It's longer than a DWV coupling and the slips are also deeper.
    John
  1. coupling seating
    By woogie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2009, 07:56 AM
  2. Help me identify odd PVC coupling.
    By Giles in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-08-2008, 12:20 PM
  3. leaking coupling question
    By FOB_Speicher in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-18-2008, 07:08 AM
  4. no-hub coupling for vent?
    By remodelbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-22-2008, 05:43 PM
  5. PVC coupling
    By Zenman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-04-2005, 01:29 PM
