Results 1 to 12 of 12
Thread: Corner toilets?
    DIY Senior Member suceress's Avatar
    Mar 2008
    LA
    Question Corner toilets?
    Awhile back I was browsing through pictures of solutions for small spaces and I happened upon a photo of a toilet that actually fits in to a corner diagonally. I'd seen corner sinks before but I admit I was fascinated by the corner toilet. I doubt I would actually get one because I think there would be space issues (depending on the size of the toilet).
    Here are three examples:
    Mod toilet from UK
    Regent Dual Flush
    Barnum Dual Flush
    I now know that American Standard makes them too.
    I am not actually thinking of getting one, but I admit my curiosity is piqued and for my edification (and perhaps just to catalog more varieties of toilets) I was wondering if anyone here had any experiences with corner toilets? Anyone heard of them or used them?
    Are they any good?
    If there are any good ones, which ones are better?
    What are the pros and cons?
    Would anyone recommend one for a small space? Why or why not?
    Also, I admit I'm also intrigued by this:
    I didn't know a sink could be put on a toilet tank (although I'm not entirely sure its such a good idea). Granted it looks like a better idea than the toilet with a washing machine as a tank. That one has so many things that can go wrong...
    Any thoughts?
    Apr 2012
    New York, NY
    I think the Titan Pro corner (triangle) toilet has been discontinued. AS's web site shows them all as "available while supplies last". Odd, as it is basically just a triangle tank on a base that they use in another toilet.
    Mar 2008
    LA
    I can't believe I didn't notice until you mentioned it that some of them are just corner tanks on top of regular toilet bases. Except for the UK one (which has been discontinued, IIRC).
    I wonder if Toto ever made any. I'm thinking they haven't, but I bet they could find a market for it.
    I wonder if any company would ever make a corner sink tank for a toilet. That would be interesting.
    Default Toilet
    Eljer's "Triangle" was the first one and is still made. A conventional toilet's pipe has to be 12" from the back wall and 15" minimum for the side walls. A triangle toilet's pipe has to be 12" from BOTH walls to fit properly. The tank is the only difference between a conventional and corner toilet. Toilet from Britain, etc., are not always IAPMO approved and might not pass a final inspection.
    Apr 2012
    New York, NY
    The Eljer Triangle (i.e. Titan Triangle, Patriot Triangle and Patriot Triangle EL), like the AS Titan Pro Triangle, may still be available out there, but they are all marked on the manufacturer's web sites as discontinued. AS does still make a Triangle Cadet Pro.
    Mar 2008
    LA
    Thanks for the info!
    The UK toilet looked like it didn't have much wiggle room and it appeared to me to be closer to the walls than it should have been, but I'm not very good at eyeballing things like that.
    The US versions are interesting.
    I like the look of the Regent one because it reminds me of some antique fixtures, but it looks like it would be uncomfortable.
    I also wonder if corner toilets actually save any space or if its just for aesthetics.
    Oh NOW the thing shows me threads called "corner toilet". When I used the search it didn't bring them up. LOL.
    Last edited by suceress; 06-27-2013 at 02:09 AM. Reason: removed photo that I realized Mr. Love posted in another thread already.
    Default toilet
    The toilets do NOT "save space" but they use it better, because you do not have to worry about "knee room" between it and a wall, tub, or sink cabinet. The "sink and toilet" combination is a Japanese idea and is not approved for the U.S, (other than stainless steel units for use in prisons).
    A toilet install in the USA requires 15" either side of centerline to any obstruction. That might be easier to attain on a corner toilet, depending on how that measurement is taken. But, as said, the bigger thing is knee room. Because there are so few choices, I would never design a new installation to require one as it limits your choices way too much for the future should you, or the person buying the house, decide it needed an update.
    Default toilet
    The "dynamics" of a corner toilet almost insure that it will be 15" away from any obstacle at the "center of the bowl" where the measurement would be taken. But since the openng will ONLY be 12" from the side wall, it can never be replaced with a conventional toilet unless the pipe is shifted. And, it would usually have a cabinet next to it which would interfere with the leg room.
    Mar 2008
    LA
    Thanks for all of the replies. I actually mentioned it on Toto's facebook page and they said they would look in to the idea of making corner toilets. Of course, they could just have been saying that as an automated response.
    I didn't realize that the toilet sinks were not approved in the US. That explains why I've never seen any of them. I don't think they would be all that great in houses, but maybe in mobile homes or something.
    I actually started to consider getting a corner toilet when remodeling my guest bath/laundry room area but there aren't any places around here that sell them.
    In the meantime, I'm trying to make 3D models of corner toilets to use as custom content for my Sims 3 game.
    Terry used to sell and ship toilets...he had a 20% breakage rate by the shippers and it just became too problematic, so he now only sells them locally, or where he has an agreement. He may have an agreement with someone in LA. Have you checked his storefront?
    His rate seems consistent with my experience...in buying 5, one got broken.
    As noted, buying a toilet on line can be problematic because of breakage. Assuming you inspect the shipment and find the breakage before accepting delivery, most dealers will make good on replacement. The problem lies in the time it may take to get the replacement. Might be wise to check with their CS before ordering to see just what their requirements are regarding damage claims and then make very certain you follow their rules carefully. Even to the extent of numerous photos of the unpacking process. As an alternative, you might want to do a bit more shopping. Toto prices can really vary for dealer to dealer.
  1. Replies: 2
    Last Post: 08-18-2010, 03:19 PM
  2. Corner toilets?
    By spaceman375 in forum Toilet Forum discussions
    Last Post: 02-03-2010, 03:58 PM
  3. Corner toilet
    By edmonds in forum Toilet Forum discussions
    Last Post: 09-14-2009, 06:58 AM
  4. Thoughts about Niagara Conservations toilets and 10" Rough In Toilets
    By wanderin in forum Toilet Forum discussions
    Last Post: 06-02-2008, 05:35 PM
  5. corner toilets
    By macska in forum Toilet Forum discussions
    Last Post: 01-01-2005, 12:05 AM
