Results 1 to 3 of 3
Thread: Stuck Moen shower stem valve
    DIY Junior Member stuckshowerguy's Avatar
    Jun 2013
    Alaska
    Default Stuck Moen shower stem valve
    Hi folks, looking for some advice on how to get a shower valve unstuck. A roommate broke the handle off a couple years ago, and i just put a new one on....and realized why the last one broke, the valve seems stuck. Won't push, pull, turn, nothing, nada. The wall plate says its a Stanodyne, picture is attached. From what I am seeing I have a feeling that if I call a plumber Im going to end up with a bigger hole in my wall and a bigger hole in my wallet, too. Any obvious tricks/tips/solutions to getting this valve to work?
    Thanks in advance!
Size:  46.2 KBName:  IMAG1004.jpg
    Moen 1225B cartridge will fix that.
    Default Moen
    quote; Moen 1225B cartridge will fix that. It WILL, after he gets the old one out, which is the problem he is asking about. The answer may be that YOU will not get it out, but a skilled plumber with the right tools, (and I have about 5 different ones to remove it depending on the situation and how it degrades as each tool is applied to the core), should be able to do it in a matter of minutes.
  1. Moen shower/tub valve leaking from stem when water is on
    By Tubal in forum Shower & bathtub Forum & Blog
    Last Post: 03-16-2013, 07:23 PM
  2. stuck shower diverter stem, frozen, identify this?
    By hauch in forum Shower & bathtub Forum & Blog
    Last Post: 02-17-2010, 07:57 PM
  3. Stuck valve stem seat
    By mikey1956 in forum Shower & bathtub Forum & Blog
    Last Post: 06-18-2008, 08:08 PM
  4. Shower Stem/ Can't Remove It / It Is Stuck
    By SLATON in forum Remodel Forum & Blog
    Last Post: 05-12-2007, 01:00 PM
  5. shower diverter stem stuck
    By Accountingcrow in forum Shower & bathtub Forum & Blog
    Last Post: 10-30-2005, 05:44 AM
