Results 1 to 4 of 4
Thread: How Much More Pressure Will I Get To My Outside Bibs If I Bypass My Whole House Filte
    DIY Member drizler's Avatar
    Feb 2009
    New York
    Default How Much More Pressure Will I Get To My Outside Bibs If I Bypass My Whole House Filte
    150' drilled well 1/2HP pump 10GPH. 60/40 switch. I have everything running through the wholehouse filter with the standard wrapped media and have for years. Lately we put in a garden further out than anything before and the pressure could be better. Someone suggested bypassing ahead of the filter for all the outside water would jack up the pressure some. The plumbing for me is no big deal so I can pull it off easily enough, the question is whether it is worth it? What say ye??????
    Feb 2011
    NW Ontario, Canada
    It all depends on the volume. At low volume there would be no pressure difference.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Take the filter out of the housing or bypass the filter completely and see what happens.
    Feb 2009
    New York
    Quote Originally Posted by craigpump View Post
    Now that I think about it I have to wonder why I didn't think of that myself???? Thanks. that's an easy way tosort it out.
  1. Low water pressure from water coming out of acid neutralizer. Bypass pressure is OK
    By rob742 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-28-2013, 10:35 AM
  2. Should I construct a bypass or use the bypass that came with my softener?
    By amateurplumber1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-15-2013, 05:17 AM
  3. Took softener off Bypass and now no water in the house???????
    By Jsalesc in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-26-2011, 12:29 PM
  4. Water Softener On = No Pressure, Bypass = Normal Pressure?
    By jsarin1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-08-2011, 04:06 PM
  5. OK For Irrigation System To Bypass Pressure Tank?
    By htrimble in forum Irrigation / Sprinkler Forum
    Last Post: 06-28-2005, 07:29 AM
