Results 1 to 2 of 2
Thread: Navien 180 ASME GAS COMBO Boiler/Hotwater heater / Carriage house?
    DIY Junior Member pkboulos's Avatar
    Jun 2013
    New York
    Default Navien 180 ASME GAS COMBO Boiler/Hotwater heater / Carriage house?
    All,
    i am renovating a lofted one bedroom space maybe 600 sq feet above 2nd floor of a carriage house. i want to purchase this unit but i am worried it may be "too big" for the space?
    i would use it for baseboard heat and hot water... would there be any downside if it was too big? it says min output BTU of 17,000k... I dont have a lot of knowledge about this and need some help.
    I need to use gas as a i dont have enough electric for baseboard heating, i like the idea of on demand because i dont know how often i will actually be using the space of it i may rent it or what.
    thank you
    Peter
    Without a heat load analysis, you won't know what you actually need, but 17K is probably 2-3x more than you need except on the coldest day of the century (this is a guess). Keeping the unit hot 24/7 to provide hot water is also a waste. There probably isn't a boiler sold here small enough for maximum efficiency, but a mini-split system should be able to handle it fairly easily along with a gas WH.
  1. Navien CH-240 / CH-240 ASME differences
    By mirong in forum Tankless Water Heater Forum
    Last Post: 08-10-2012, 09:30 PM
  2. Boiler/Water Heater combo for townhouse
    By FlemishBond in forum Water Heater Forum, Tanks
    Last Post: 12-02-2009, 08:24 PM
  3. PEX and hotwater heater
    By David Oetinger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-25-2009, 07:10 AM
  4. gas hotwater heater
    By Ed from chicago in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2007, 04:33 AM
  5. electric hotwater heater trouble
    By markmark in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2007, 02:30 PM
