Results 1 to 4 of 4
Thread: Leaking "S" Trap issue
    DIY Junior Member haywood21's Avatar
    Jun 2013
    New York
    Default Leaking "S" Trap issue
    So I replaced the pipe under my sink and after putting the water on full blast (testing phase), I noticed a small dribbling leak of the left side of the pipe. I have an image of it.
    1. the dribble
    2. where the water ends up going
    Any suggestions?
    Thanks in advance.
    Default leak
    1. That is an illegal "S" trap 2. When you installed the washer you probably put it OVER the bead on the "U" bend instead of against it.
    Yakima WA
    Suggestion? Yeah, get rid of the S trap and install a P trap with a proper vent. Might want to be sure the washer(s) are installed correctly on the P trap while you are at it.
    Jun 2013
    New York
    Exact diagnosis.
    Thank you for the help.
  1. P-Trap Drain Not Draining Issue
    By jms87 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2013, 08:41 PM
  2. shower to tub drain issue ( 1 1/2 to 2 p-trap)
    By clapfc in forum Shower & bathtub Forum & Blog
    Last Post: 11-27-2012, 12:10 PM
  3. New vanity install - P trap issue
    By bones2116 in forum Remodel Forum & Blog
    Last Post: 03-16-2012, 03:42 AM
  4. Need some help with possible J trap height issue...
    By siberian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2006, 03:59 AM
  5. P-trap sink issue
    By jgeibel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2006, 06:55 AM
