Results 1 to 8 of 8
Thread: viberation in franklin electric pumptec
    DIY Junior Member penrosepete's Avatar
    Jun 2013
    penrose, Co.
    Default viberation in franklin electric pumptec
    My well is about 12yrs. old just the other day there was a viberation in the pumptec about 20-30 sec. before it kicked off, never done this before 3 days later it done it again, it is quite loud.any ideas, I know it is not good.
    Moderator valveman's Avatar
    Mar 2006
    Was it the pumptec that tripped the pump off, or the float switch?
    Jun 2013
    penrose, Co.
    The float switch at the right pressure
    Mar 2006
    I don't know why the pumptec would be making noise 20-30 seconds before the pump shuts off, if the float switch is turning off the pump. The pumptec doesn't know the float switch is about to turn the pump off. But if the relay in the pumptec is bad, it could be buzzing just before it turns off the pump.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by penrosepete View Post
    I think you may be mixing two different things. A float switch responds to level, not pressure. A pressure switch responds to pressure. You might have some bounce/chatter on a failing pressure switch causing the relay to also bounce/chatter. 20/30 seconds however is a very long time. How long is a pump cycle if there is no draw?
    Jun 2013
    penrose, Co.
    O K now it makes the noise just as soon as the pump kicks on at 22# and quits when the pump shuts off at 48#, You can feel a little viberation on the pumptec if you put your hand on it. I can,t understand the noise, but I don,t even know how it works, my pump man said it would keep my pump from burning up. the pump and well seem to be working ok. do I replace it before it shuts my well down? Please advice.
    Jun 2013
    penrose, Co.
    I guess it sounds like I need to replace the pumptec, Do I just shut the power off and take out the old and rewire the new, is there any adjustment you have to do or does it come already to install? Please help
    Mar 2011
    Houston, TX
    Just get the proper power and Voltage Pump and it should be a easy change out.
    It sounds like you may have a Motor Bearing going bad.
    The Bearing can be replaced maybe if you have a press. Or you could replace the motor, that may be a bit cheaper then the whole pump.
    Good Luck.
  1. replaced my wells pump ,Franklin control and Pumptec boxes yesterday. pics incl.
    By Timbuktu in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-01-2013, 08:46 PM
  2. Franklin Electric Sub Drive 75 Constant Pressure system
    By molinsky in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-27-2011, 07:10 AM
  3. Franklin Electric control box making chattering noie
    By mnkcon in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-07-2011, 08:01 PM
  4. Franklin Box Parts
    By Rutherfordman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-26-2010, 02:59 PM
  5. Franklin motor parts
    By FLATFLAME in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-02-2007, 06:40 AM
