Thread: posssible tank pressure @ 18 psi, shut-off at 50?
    DIY Junior Member serenityvalley's Avatar
    Jun 2013
    New Mexico
    Default posssible tank pressure @ 18 psi, shut-off at 50?
    My captive-air bladder tank is supposed to be 40 psi, with the cuton/off at 40/60, according to the manufacturer.
    The gauge reads cut on at 50, off at 60, and the tank reads 18 psi (by use of tire gauge).
    Is this even possible, or is something not calibrated properly?
    We have low water pressure, but no short-cycling, no water coming out of the tank valve, tank appears to have water in it.
    Thanks for your help.
    Feb 2011
    NW Ontario, Canada
    When the water pressure is higher than the precharge, both should read the same.
    Moderator valveman's Avatar
    Mar 2006
    Put 35# of air in the tank and see if it stays.
  1. why is a pressure tank with a bladder better than plain old steel pressure tank
    By fcbclan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-26-2012, 02:56 PM
  2. How to properly shut off one hot water tank in a parallel system?
    By joeyw in forum Water Heater Forum, Tanks
    Last Post: 09-09-2011, 06:20 AM
  3. Need Some Help Please: Control Valve Doesn't Shut Off Brine Tank Refill
    By Biddle in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-22-2011, 04:18 PM
  4. tank will not shut off
    By Kuba83 in forum Water Heater Forum, Tanks
    Last Post: 08-12-2010, 12:40 PM
  5. Pump won't shut off - no pressure
    By hattereno in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-10-2006, 07:00 AM
