Results 1 to 8 of 8
Thread: Well-X-Trol worth the price ?
    DIY Member Arky217's Avatar
    Jan 2008
    Arkansas
    Default Well-X-Trol worth the price ?
    I can buy a 44 gal Amtrol Well-X-Trol tank for $429.
    Amtrol also makes the Water Worker brand; I can buy a 44 gal Water Worker for $229.
    Being that both are made by the same company, is the Well-X-Trol really worth the extra $200 ?
    Water Worker warranty = 5 years, Well-X-Trol = 7 years; but since the Well-X-Trol
    tank is nearly twice the price, will it really last longer than two of the Water Worker tanks ?
    Arky
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Spend the extra money.
    We see Well X Trol tanks last 20+ years
    The difference is in the diaphragm, the Well X Troll is rated for 150psi
    DIY Junior Member sc_hoaty's Avatar
    Jun 2013
    SC
    My Well X Trol is about 30 - I've owned it the last 26. I need to add air every 5-7 years.
    Moderator valveman's Avatar
    Mar 2006
    The quality of the bladder in the tank is not nearly as important if you eliminate most of the pump cycling. When the pump cycles on and off, the bladder bends back and forth like bending a wire until it breaks. Cycle the pump 100 times per day and you need 5 times as good of a tank than if you use a CSV and only cycle the pump 20 times per day.
    Jun 2013
    SC
    When my Well X Trol finally dies, I will look into a CSV. At the moment, the Well X Trol is on its way to outliving me!
    Mar 2006
    I have a Well X that was installed in "82". Still has all but 5 PSI of the original air. But it has worked with a CSV since "94". So not really a good test because it only had 12 years of regular cycling on the bladder before the CSV was installed.
    Apr 2012
    ct
    Valveman, I think you have gotten your money's worth out of that tank.
    Jun 2013
    SC
    Go ahead and add some "new" air to it. It deserves a treat after all those years of faithful service!
  1. well-trol will not regulate
    By confused in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-19-2008, 02:47 PM
  2. Is SanaGloss worth the price?
    By Otto in forum Toilet Forum discussions
    Last Post: 10-01-2007, 10:40 AM
  3. Brand New Well X Trol and Now What??
    By billrok in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-27-2007, 08:15 AM
  4. Do faucets with ceramic valve worth the price?
    By curious in forum Remodel Forum & Blog
    Last Post: 01-01-2007, 10:25 AM
  5. Well-x-trol 202
    By hammy233 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-16-2005, 02:01 AM
