Results 1 to 2 of 2
Thread: Well Water Newbie
    DIY Junior Member OZ324's Avatar
    Jun 2013
    Virginia
    Default Well Water Newbie
    Just bought a 12 year old house with a well. It has a softener already and what I think is a spin down sediment filter before the pressure tank. It's missing the cartridge, how do I know which cartridge to purchase for replacement? Are these types of sediment filters good, or should I invest in something better?
    I don't have any foul smells, taste or discoloration.
    Thanks in advance.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Where is the pressure switch mounted? You NEVER want to have a filter before the pressure switch because if and when the filter plugs, the pressure switch won't be able to sense the increased pressure causing the pump to continue to run. A large enough pump set in a deep well full of water will make enough pressure to blow pipes apart and can even rupture a tank and turn it into a small rocket.
  1. Newbie here! problem getting water from my lake
    By MUGSHOT in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2013, 05:10 AM
  2. Connecting Hot Water Baseboards - Newbie to Pex
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2010, 06:19 PM
  3. Strange hot water problem! Help a newbie!
    By kissiffer4 in forum Water Heater Forum, Tanks
    Last Post: 12-05-2009, 02:53 PM
  4. Newbie Forced-Hot Water Help in Frozen NH
    By NHCasey in forum HVAC Heating & Cooling
    Last Post: 12-15-2008, 07:04 PM
  5. Water heater questions from a newbie
    By DBS2071 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2008, 08:22 PM
